Francesca Knowles
Port Hadlock, Washington
At Semi turning radius there's a formula for calculating this number for 18-wheelers,...
Here's the image from the site showing an approximately 40 ft trailer with a tractor I believe to be about the length of a 40 ft. 5th wheel's TV.:
![[image]](http://www.thetruckersreport.com/images/TruckSide.jpg)
Does the formula at the site hold true for a 40 ft. 5th wheel RV, despite the more forward placement of the RV's wheels?
And if not, how is the radius affected, that is, is more or less room required?
Thanks!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Fulltimer50
Kerrville, Tx
Turning radius has to do as much with the truck as the trailer. The sharper the turning radius on the truck the sharper it will be with the trailer.
The wheel location on a 5th wheel is no where close to that of a semi trailer.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
Brewurown
Morganton, NC
I would think that turning radius would depend on the TV wheelbase. I have a long wheelbase and I need 40 acres.
Al
2011 Berkshire 360FWS
2010 Montana Mountaineer 335 RET
Hickory Foothills Good Sam Chapter member
NC Hauler
Pence Springs WV
I too have a long wheel base truck, but I turn my 39' 6" 5er around in our cul-de-sac. When I make the turn, the inside tires "skew" until I complete my turn, but with the wheels half way back on the 5er compared to all the way back on the semi-trailer, it makes for a tighter turning radius. I could measure across the cul-de-sac, which I take every foot to use to make my turn around in if that would help, but I believe most would be surprised with how little it does take to turn around an almost 40' 5er hooked to a long bed Crew Cab dually.....I'm speaking from experience...I have to do it everytime I bring my 5er home from a trip so that I can back my 5er into my drive way.
On edit: I don't have to dodge anything when turning around in the cul-de-sac...it's not like pulling into a filling station and trying to avoid hitting fuel pumps or poles, etc (meaning having to make an even wider turn)...I'm talking about just making, basically, a U-turn with truck and 5er.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Francesca Knowles
As I understand it, turning radius is affected by both the length of the rig and the placement of its wheels.
I'm hoping somebody out there understands the math involved well enough to tell me how the formula would differ for a rig with the wheels (pivot points) situated differently than those on the rig in the picture.
When trip planning, the widths of ingress/egress roads and sharpness of campground curves is readily available...
It's be nice to be able to make a real determination of accessibility before deciding on destinations!
sirdrakejr
Las Vegas, Nevada
While the turning radius of a 5th wheel turning is shorter, the rear end swing of a 5th wheel will be much more. A semi truck's rear end has a very short overhang and the swing is minimal. A 5th wheel has almost 1/2 of it's length as overhang and that swing will give you grief if you do NOT remember to allow for it and miss any objects close to the end of your combo.
Practice, practice, practice. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Frank
skylos
Columbus, OH
The radius is reduced by the shorter kingpin-to-rear-axles distance. Effectively, your 42' in the picture is like, 20'.
The back end of the trailer will swing out a good distance, but that can be over grass or sidewalks or whatever, its merely important that it not be trees...
John Bridge
Houston
Turning a fifth wheel trailer has more to do with the distance between the pin and the midway point between the trailer axles. I have a long wheelbase truck, and I, too, can turn my forty-foot fiver in my cul de sac. I probably wouldn't be able to do it with a forty-foot semi-trailer without meeting up with myself.
Semi-"retarred" in 2006. :-) 2008 Newmar Cypress 5th wheel, 2008 Dodge diesel dually to pull it with.
RoyF
Fayetteville Arkansas
If the truck can make a u-turn, the trailer (fifth-wheel or other) follows. The outside track will be made by the steering tire of the truck. The length or wheelbase of the trailer is a red herring here.
ps: I think I misunderstood the question. I was thinking about minimum size of a complete circle. Disregard this, please!
kab449
PA
Each trailer will be different depending on the distance from the kingpin to the center point of the trailers axles. Your task will be to learn when driving your rig how far to the inside the trailer tires track in relation to the track of your tv. This is a judgment learned as previously stated by practice, practice, practice.
2017 Heartland Bighorn 3160Elite/2017 F250 Lariat Ultimate
2018 Coachmen Galleria 24Q Class B Mercedes Van
Keith & Brenda
Marley the Maltese
Central PA
