RV.Net Open Roads Forum: Calling all Road Warrior owners - RWS, RWT, RWM
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Calling all Road Warrior owners - RWS, RWT, RWM
Page of 40
Msgtsniper
Kalispell
Posted: 09/06/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I trimmed the brackets. Cut them off just above the upper hole that isn't used.
09 Road Warrior RWM3400
TheoWarrior
near durango Colorado
Posted: 09/06/21 09:15am Link  |  Quote  |  Print  |  Notify Moderator
ksanford wrote:
KMiller..how much trouble was it to get the carpet out from under the slide?
Sorry Msgtsniper, the placard on ours is faded, too
I replaced my carpet with vinyl click type flooring.
getting the old carpet out from under the slides was a pain but not unmanageable I blocked up the slides and just physically pulled the carpet out from under.
I think it was stapled or tacked in place. If you have friends or a couple of people to help you pull on it. I didn’t have help so Ibasically folded it over to get a good grip on it and then pulled it out using a come along.
TheoWarrior
Posted: 09/06/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply I’m working on that right now.
Did you install rear sway bars also?
This sounds kind of stupid but I think I just figured out there’s a stock sway bar back there and I’m wondering if it’s worth it replacing it with a roadmaster.
Msgtsniper
Kalispell
Posted: 09/06/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
It's personal feel, some do install additional rear some don't. I did and think it was totally worth it. Took away a lot of rear sway so the coach is more pleasant to drive.
TheoWarrior
Posted: 09/06/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Do you have to remove the old sway bars or do you add the new sway bars along with them?
Msgtsniper
Kalispell
Posted: 09/06/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
The additional rear sway bar goes behind the axel to work with the existing sway bars. For a total of three.
TheoWarrior
Posted: 09/06/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Awesome thanks for the quick reply I’m in the process of installing the rear sway bar now.
TheoWarrior
Posted: 09/06/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Here’s another dumb question
have you guys figured out how to cool down the hot water
I don’t know of a mixing valve unless you use the water heater bypass valve as a mixing valve To cool down the scalding hot water that comes out of your water heater?
Msgtsniper
Kalispell
Posted: 09/06/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Usually you supplement the hot water with the cold water on each fixture.
TheoWarrior
Posted: 09/06/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Nice.
Page of 40
