RV.Net Open Roads Forum: Calling all Road Warrior owners - RWS, RWT, RWM
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Calling all Road Warrior owners - RWS, RWT, RWM
Page of 28
TheoWarrior
near durango Colorado
Posted: 04/04/18 08:56am Link  |  Quote  |  Print  |  Notify Moderator
The water tanks are visible in the front sections of your compartments on both sides. If yours is like mine, you have two water tanks, and a grey water and black water tanks visible in the rear of the water fill and sewer dump compartment.
CoeyCoey
Colorado
Posted: 04/07/18 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Theo,
I dont have one yet. I am in the market (kinda) for a RWT3400. Still waiting for my condo to sell. Going to live in it full time.
kmiller
San Diego
Posted: 07/10/18 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
d: 07/10/18 12:56pm Link | Quote | Edit | Print | Notify Moderator
Requesting some help.. I need the lens number on the upper top rear LED Light indicator that functions as turning signal that is in the middle, for sequential left and right and also as a stop signal. Any Ideas on where I could order the correct light would be highly appreciated. In haste I had to replace a few months back the light with one ordered from Warrior Lifestyle which was not the same wires, by the way is close permanently. When I received the light from them it was incorrect. The one on the warrior has 4 wires, instead they gave me 3 wire. They said it would worked and I installed. I realized on my travels when I have the headlights on the passenger turning signal would not work after troubleshooting it and my limit electric experience I finaling found out. Sorry for how long it took to explain,but I didn't want you to think I was lazy to look myself, I threw the old one away. Your help would be greatly appreciated.
Radrnut
Bakersfield, Ca.
Posted: 08/25/18 10:12am Link  |  Quote  |  Print  |  Notify Moderator
kmiller, check out weekendwarriorpartsandservice.com. I believe these are the same guys as warrior lifestyles, I think they just moved and reorganized. 1-800-500-9914 or 1-951-349-0796. Address is 166 Commercial St. Perris, CA. 92570.
Rigo232003
Southern Cali
Posted: 01/14/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Picking up a (new to me) 2009 Road Warrior RWM3400 with 6897 miles on the odometer this week. I just replaced all 4 batteries yesterday and was looking around the rig to see what it needs. Two questions
1) is there a switch somewhere to get power to the house radio (next to the side door) I can't wait to see what the system sounds like with the amp and the sub woofer up on the wall.
2) I was not able to get the screen for the back up camera to turn on. Head unit turns on but the screen won't move and the power lights stays red.
Any help or advice would be greatly appreciated. Can't express how excited I am to get this thing. Selling my toy hauler and this is going to be our first motorhome!
Been going through this topic on the forum for several days now. Love all the info.
Thanks again!
kmiller
San Diego
Posted: 01/15/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Hi Rigo232003, Congratulations on your purchase! I also live in SD. On your radio with cabin power& radio power button on maybe a breaker? My cabin breakers are located next to the frig. On your camera the screen will only move inwards in radio unit by line the screen up square with the unit. Your exterior camera can move up and down to view the rear. Once adjusted I just leave my screen and the rear camera alone. The rear camera has a coax cable and can get fatigue by moving repeatedly.
Rigo232003
Southern Cali
Posted: 01/16/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
RANDOM QUESTION,
ARE THE LOWER STORAGE COMPARTMENTS STRON ENOUGH TO HOLD A FULL ICE CHEST? THEY CAN WEIGHT A TON.
kmiller
San Diego
Posted: 01/18/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Never tried to fit a cooler. Our bins are small.
* This post was edited 01/18/19 08:58am by kmiller *
kmiller
San Diego
Posted: 03/25/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced there Jensen VR187 stereo?
TheoWarrior
Posted: 04/11/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have had to reset my radio several times to get the screen to work.
Same with the entry radio, I also had to hook it to a hot wire to get it to work on a trip and I’ve been too lazy to try to figure out why the original power source stopped working
You’re going to find out that whoever wired these motorhomes did a very poor job and most of the connections are loose and poorly done. Whetnever you find something that’s not working just assume it’s a loose wire and take the unit apart to find the feeder wire and you’ll probably find a pinch not that wasn’t properly installed.
One of the first things I would recommend is pull out the microwave oven and locate Find the switch box behind it, it switches power from shore power / generator power etc. if you start the generator you will hear it switch after a minute.
Open the box and then tighten the electrical connecting lugs...
my unit burned up and it’s very common problem. The manufacturer recommends getting into it and tightening the lugs in your switchgear every year which is actually common practice for switch boxes on mobile equipment. While you’re at it open the breaker box under the microwave and take the cover off of it and tighten all the 110 power wires going to that.
mine had loose wires and was arcing. This is the transfer switch in your rig
WFCO T57 50 Amp Transfer Switch https://www.amazon.com/dp/B009LFZZFK/ref=cm_sw_r_sms_c_api_i_k4aSCbRZAAQKT
* This post was edited 04/11/19 10:01pm by TheoWarrior *
Page of 28
