RV.Net Open Roads Forum: Calling all Road Warrior owners - RWS, RWT, RWM
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Calling all Road Warrior owners - RWS, RWT, RWM
Page of 29
kmiller
San Diego
Posted: 04/11/19 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, funny you mention that a wire was loose on my lug for my house and the wire was arcing. I'm going to pull the microwave out, I have a drawer under microwave . is that the same set up on yours?
TheoWarrior
near durango Colorado
Posted: 04/11/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
kmiller wrote:
Never tried to fit a cooler. Our bins are small.
I would say no.??
TheoWarrior
Posted: 04/11/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
[quote=TheoWarrior][quote=kmiller]Never tried to fit a cooler. Our
My microwave is under the range.
The Generator : shore power switch box is probably near your breaker box. I had a very hard time finding it. Like I said when you turn your generator on and it runs for a minute you can hear the switch clicking when it kicks on and runs everything off generator power. that’s one way to find it!
kmiller
San Diego
Posted: 04/12/19 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
RZRHog
Peoria, AZ
Posted: 07/15/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Good Evening All,
Need some help with the generator and am hoping there is an easy fix. The generator starts will run for a bit then cut out. It will do this both under load and not. There is not a specific amount of time before it cuts out.
Any assistance is appreciated.
Thank you
kmiller
San Diego
Posted: 07/15/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Taking a stab at it , it sounds like a fuel issue. Maybe a fuel filter, they are some what inexpensive to try.
RZRHog
Peoria, AZ
Posted: 07/15/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
It was just changed a couple moths ago but good idea and I will give it a shot.
Thank you
kmiller
San Diego
Posted: 07/15/19 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I know if you don't keep them exercised monthly full power the carvery will come up. I'm not sure if you're aware. But, you also have an error code on the generator. The generator has a indicator that will blink, I believe it's green, each blink will determine the problem your occuring.You can Google the model of generator to get the troubleshooting guide.
kmiller
San Diego
I meant to say carburetor will gum up.
TheoWarrior
Posted: 07/15/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have the manual and the codes if you need a copy.
You also can’t run your generator on a tank under 1/4.
It will shut down Automatically if you u get to a quarter of a tank
* This post was edited 07/15/19 09:02pm by TheoWarrior *
Page of 29
