RV.Net Open Roads Forum: Class A Motorhomes: Allison Mode Button
 > Allison Mode Button
kedanie
Albuquerque, NM
Posted: 03/01/12 10:00am Link  |  Print  |  Notify Moderator
We are new to this Class A DP. It was purchased "lightly used" and we are still trying to figure out a few things.
The coach has a 340hp Cummins with a Allison 2500 6 speed trans. The trans control has a button marked "Mode". I looked through the manual and couldn't find anything about it. Can anyone tell me what it is supposed to do? The dealer PDI guy said that it makes the trans down shift less.
Any info will help,
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
skipnchar
Topeka or somewhere else
Posted: 03/01/12 10:07am Link  |  Print  |  Notify Moderator
Push the button to see what happens. Most likely outcome is it will turn on the "tow/haul" mode, and push it again, to turn it off. Should also light up on the dash to show it's on. Tow/haul will change the shift points to prevent the transmission from shifting as often, thus reducing heat when working hard. Probably also will provide automatic downshifts on long downhill grades to control speed.
downtheroad
Pacific Northwest
Posted: 03/01/12 10:18am Link  |  Print  |  Notify Moderator
Whatever you do, DON'T PUSH THAT BUTTON!!
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Deetour
Washington
Posted: 03/01/12 10:22am Link  |  Print  |  Notify Moderator
Big Katuna wrote:
It switches Economy mode on and off. Lowers the ups oft point and raises the downshift point. Wont make much difference on flat land but will downshift less in rolling hills which will save some fuel. No light on dash. A red light comes on by button.
This is the correct answer.
Two Hands
California's Central Coast
I just saw an article about this mode button, but only read a little of it because I don't have a diesel engine. I don't know if the article was in the most recent FMCA magazine or a Motorhome magazine. Perhaps someone will know the source of the article.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
Big Katuna
Deland, FL
Posted: 03/01/12 10:13am Link  |  Print  |  Notify Moderator
My Kharma ran over my Dogma.
polly sue
Colorado
Posted: 03/01/12 10:26am Link  |  Print  |  Notify Moderator
The current Motorcoaching Mag of FMCA has the article and I found it pretty informative.
bluwtr49
Green Valley, AZ
Posted: 03/01/12 10:38am Link  |  Print  |  Notify Moderator
There is no such thing as a tow/haul function on the Allison. This is to shift to an Economy mode that allows the engine to lug longer before downshifting. By running at max torque longer and allowing the speed to drop, fuel efficiency is improved.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
wolfe10
Posted: 03/01/12 10:44am Link  |  Print  |  Notify Moderator
The article is also out on the March 2012 e-Newsletter that just came out today and was e-mailed to all FMCA members who get e-newsletters.
Just click on "Allison Transmission Mode Button" (assuming you are a member of FMCA).
Brett Wolfe
2003 Alpine 38'
RCtime
So. Calif.
Posted: 03/01/12 11:12am Link  |  Print  |  Notify Moderator
I use it almost exclusivly. I prefer its shift points.
I cruise about 62-63 mph. with it on, it shifts to 6th about 55 mph, with it off about 58. a little cushion before downshift, It also holds in gear a little longer before down shift when in rolling hills.
Once up to speed on flat terrain there is no difference.
From a stop sign the shift points will come a little quicker.
Just turn it on and try it out.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2013 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel, RIP
TT/N
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
