RV.Net Open Roads Forum: Tow Vehicles: Trucks
Search only in Tow Vehicles
 > Trucks
retired-tech
flint mi
Posted: 03/20/12 06:36am Link  |  Print  |  Notify Moderator
at that length i would go dually. it will just give you a little peace of mind when towing that long trailer. it takes a little getting used to but once you do it is no big deal. also the price is not that much different. i dont regret going bigger even with my little tiny trailer.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
five'er
Canada
Posted: 03/20/12 06:44am Link  |  Print  |  Notify Moderator
Based on the commercial I saw Dodge is the only choice, the impression I got was if you choose anything else you simply need to watch it again. It might also be worth noting that the legendary Cummins engine apparently scares off ford trucks when in a face off situation in old western towns.. They also showed the three in a race in some desert and the Dodge was clearly in the lead.. Just saying.. [emoticon]
pretty funny commercial
* This post was edited 03/20/12 06:55am by five'er *
Eric727
Denwood ,Alberta
Posted: 03/20/12 07:14am Link  |  Print  |  Notify Moderator
i Had to do that choice 2 month ago and look at my pics below and you will know the awnser
but all will tow fin .its personal choice if you look at all the big 3
2012 Ram 3500 Longhorn/Crew Cab/DRW
2010 ram 1500 TRX4 (trade for the longhorn)
2012 Lacrosse 318BHSS
2008 trail lite crossover(trade for the 318BHSS)
4x4ord
Canada
Posted: 03/20/12 07:43am Link  |  Print  |  Notify Moderator
Do you have good idea as to what that big Dodge gets for highway mileage yet?
2016 F350 SRW Platinum short box 4x4.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
2BLAZERS
KEIZER, OREGON
Posted: 03/20/12 07:54am Link  |  Print  |  Notify Moderator
Do what I did! Dodge Ram 3500 Dually Crew Cab 4*4, 4.10 gears and hauling and towing perfection!
2016 Dodge Ram 3500 CC Dually Cummins,Aisin,Laramie,4*4,4.10,14K
2017 Stealth WA2916 Toyhauler
2011 Arctic Fox 1150 Drybath
2009 Polaris RZR w/fun parts
2014 Polaris 850 HO Scrambler
1977 K5 Blazer 1 ton modified
2005 Pace Enclosed Trailer - Toybox
SoCalDesertRider
Arizona desert
Posted: 03/20/12 08:29am Link  |  Print  |  Notify Moderator
Boy, this is going to be quite a thread. We have almost all of the major debates in one topic:
Ford-vs-GM-vs-Dodge
Dually-vs-Single
New-vs-Used
Shortbed-vs-Longbed
All we need is Diesel-vs-Gas and 4wd-vs-2wd and we will have ALL of the major debates bundled into one hot topic! [emoticon] [emoticon]
Anyone for popcorn???
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
SoCalDesertRider
Arizona desert
Posted: 03/20/12 08:36am Link  |  Print  |  Notify Moderator
If I were buying a NEW heavy duty pickup today, it would be a Dodge, Dually, Diesel, Crew Cab, 4wd, Long Bed, Manual Trans, 4.10 axle, SLT trim.
If I wanted a NEW pickup with single rear wheels, I would buy an F350SRW, 4wd, 6.2 gas, 4.30 axle, Crew Cab, Long Bed, XLT trim.
If used, well I already have what I wanted in used trucks. See signature. [emoticon]
SoCalDesertRider
Arizona desert
Posted: 03/20/12 08:45am Link  |  Print  |  Notify Moderator
As much as I like the new Dodge trucks, to get any serious payload capacity with the Dodge, you must go with the Dually.
The single rear wheel Dodge trucks just don't have high enough RGAWR, GVWR and Payload capacity to compete with the 350/3500SRW trucks from Ford and GM.
Maybe some day Dodge will upgrade their 3500SRW trucks with significantly higher RGAWR and GVWR to match the other 2 brands but, at this time, Dodge simply does not compete with the other two in that category.
The Dually trucks from all 3 brands are pretty evenly matched for RGAWR, GVWR and Payload capacity.
whporwil
Minnesota
4x4ord wrote:
The new 1 ton SRW trucks will easily handle a 15,000 lb trailer. All three are pretty amazing trucks but the GM lacks allot of details that Ford has included - things like more power adapters, LCD screen, the Ford mirrors are a huge upgrade over GM's, much nicer locking council, 120 volt inverter, 7 wire and 4 wire trailer plug. Heated seat switch for passenger that can be turned on without climbing across the truck. The Ford shows what gear the transmission is in and allows the driver to lock out any number of the top gears. Ford has a bigger back seat with no hump in the middle, the back seat folds forward allowing for a bit of storage behind the seat as well as having the seat lift up to access storage bins underneath. More comfortable seats and if you get the King Ranch the leather is genuine leather as apposed to the pleather of the GM. Ford comes with factory running boards. Personally I wouldn't buy an older Dodge unless you like the idea of your truck feeling like a tractor even though the Cummins is a great engine.
Engineer9860
Eagle Scout dad
Posted: 03/20/12 09:02am Link  |  Print  |  Notify Moderator
CREATO wrote:
Mile High wrote:
Ford is the only tow vehicle endorsed by Toby Keith for towing - the others are just toys.
Well...you asked!
Seriously you would be better off in the TV section, and narrowing down your question to a few topics.
X2
If there good enough for Toby Keith and Allen Jackson there good enough for me.
Isn't Toby Keith the guy that smokes weed with Willie?
In Memoriam: Liberty Belle
 > Trucks
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
