RV.Net Open Roads Forum: Fifth-Wheels: Backing Up to Engage Hitch
 > Backing Up to Engage Hitch
Page of 5
johnrbd
San Joaquin Valley
Posted: 03/20/12 03:38pm Link  |  Print  |  Notify Moderator
I have no problem backing my ext cab by looking into the center rear view mirror and lining up the arrow on the hitch. When I park it at home, I don't change the elevation of the 5vr, so next time I hook up, just backed until it locks. Piece of cake. if you can't see it, then.........
Old-Biscuit
Verde Valley
Posted: 03/20/12 03:40pm Link  |  Print  |  Notify Moderator
Hey whatever works......glad that mirror does the trick for you.
Might come in hand for others.
Thanks for the suggestion.
I just back up until I hear the latch snap into place or GF screams......I've heard both [emoticon]
johntank
North MS
Posted: 03/20/12 03:47pm Link  |  Print  |  Notify Moderator
belairbrian wrote:
Why can't you see the hitch?
I just turn and look back. I have a crew cab and a tool box but can still see the hitch.
Same here, and I'am just 5-6. Truck is a 07.5 Quad Cab Dodge 3500 DRW 4X4 with a 65 gal combo tool and fuel box.
8ntw8tn
Southeast Iowa & Texas Hill Country
Posted: 03/20/12 03:54pm Link  |  Print  |  Notify Moderator
I attach a rear view camera to my back window with a big suction cup to see the hitch as I had a neck fusion and cannot turn my head as far as I used to.
Same here except I've permanently attached mine with an adhesive. I'm tall enough to see the hitch but have a neck & back injury that makes it difficult to turn that far. Technology is great.
'04.5 Dodge Ram 3500 Quad cab 4x4 SLT dually w/5.9 H.O. Cummins; PacBrake; Smarty Jr.; Raptor 100 lift pump; egt & tranny temp guages;rebuilt tranny;
'06 Carriage Cameo LXI F35CKQ w/MorRyde pinbox
Det 1 56th SOWg
SolidAxleDurango
OK, USA
Posted: 03/20/12 03:57pm Link  |  Print  |  Notify Moderator
pcm1959 wrote:
I can't see the hitch head fron the drivers seat at all in my truck either. phillip
[emoticon]
I'm an impressive 5'8" and can see mine just fine.. LOL
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 "> ) 14 Arctic Cat Wildcat 1000
johnrbd
San Joaquin Valley
Posted: 03/20/12 04:02pm Link  |  Print  |  Notify Moderator
That's one reason DW does get involved whatsoever in our preparations. I load/unload everything except her. She comes out of the house to check the lights and lock the gate behind us. Also, I park it without her "assistance" also. Keeps things on even keel.
juzplanekrazy
Riverside Ca
Posted: 03/20/12 04:08pm Link  |  Print  |  Notify Moderator
I can't see mine either. I just line up between the slider window, get within 5-6' get out take a peak, adjust heigth as needed and back in. I'd more then likely screw up if I could see it.
2008 Ford F-350 4x4 Dually
2007 38' KZ New Vision Toy Hauler
Pullrite Super5th
7.3 psdman
Northern Illinois
Posted: 03/20/12 05:15pm Link  |  Print  |  Notify Moderator
Thanks for the tip I will try that. I have a hard time judging when the pin is centered to the hitch, even looking back, and I can see where the mirror would straighten the line of sight better. Trying to adjust, side to side just doesn't work for me when I am getting close to the hitch. It's either centered or it's pull up and try again. My Reese 18K has to be pretty close because it has the single finger, on the one side that wraps around and that makes the slot a little tighter.
bpounds
Senile, er I mean
Posted: 03/20/12 05:26pm Link  |  Print  |  Notify Moderator
slarsen wrote:
Anyway, here is what I found and did: Got a small mirror with a handle on it ($5 at Target) and I hold it up high, up against the ceiling of the truck. Now I can SEE the hitch. What a difference in quick and easy hookup and knowing right where I am.
I appreciate you taking the time to share your tip with us. And apologize for us taking the thread sideways. I can see my fiver plate in my rearview mirror, but someday I may have a crewcab and this tip could be useful.
I have found that my Vee tailgate is helpful for lining up the pin. If I center the pinbox on the Vee, then it is a straight shot right into the jaws. Don't really need the mirror, except to judge distance.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
N3YMY
Brunswick, MD
Posted: 03/20/12 07:12pm Link  |  Print  |  Notify Moderator
My daughter's child seat.
Although using the side mirrors mostly corrects that.
I do miss the direct sighting via the rear view though...
Page of 5
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
