RV.Net Open Roads Forum: Camping in the bed of my pick-up ?
 > Camping in the bed of my pick-up ?
LoveMyPick-up
Posted: 03/29/12 11:42pm Link  |  Print  |  Notify Moderator
hey thanks again for your suggestions and comments. i like all of what i have been reading.... and the pictures are great.
i especially love the trick of closing the corners of the tarp in the truck doors.
thanks so much.
NorthernLimits
Michigan
Posted: 03/30/12 12:22am Link  |  Print  |  Notify Moderator
Pretty big stretch of the imagination to have this thread left in the TC forum and not be moved by now and be 3 pages.
JimBollman
Lost State of Franklin
Posted: 03/30/12 06:19pm Link  |  Print  |  Notify Moderator
You're camping in the back of a truck, so where else would it belong. Just a minimalist approach.
Jim...
realter
Eastern NE
Posted: 03/30/12 09:26pm Link  |  Print  |  Notify Moderator
Just don't SLEEPWALK while sleeping in the bed of your truck, that first step in the dark is a killer.
Farmerjon
Niangua, missouri
Posted: 03/30/12 10:16pm Link  |  Print  |  Notify Moderator
sounds like you have come up with a good solution.
I used to camp in the back of my 56 chevy by bolting a wooden frame together using the stake pockets to hold the uprights and tying a tarp over it. during a heavy rain it wasn't fun but for dry weather it worked great.
2015 F350 Lariat DRW CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat DRW SC LB 4x4 DRW 7.3, 6sp manual 3.73
99 Star Craft 953
Photog101
Garden City, Michigan
Posted: 03/31/12 03:45pm Link  |  Print  |  Notify Moderator
A long time ago, I used a tarp with three PVC pipes that fit into the stake pockets. I used it for for those quick weekend runs to go sport-chuting. I'd usually have to drive 1000 miles or so to get to a jump site and when I got there, I could throw it up in a few minutes and get some sleep before the next day's jumps. Later I found a Sportz Truk Tent that had plenty of room for myself and my gear. I would set it up before I left, with everything inside of it and then collapse it into the bed and cover it with my tonneau cover. When I got to the airport, I pulled back the cover and set it up, blow up the air mattress withthe battery powered pump, on cold days I would even have heat and usually within less time than to build the old tarp system it was ready to go.
Video of interior of Truk Tent.
Available through Sportsman Guide
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
Camper_Jeff_&_Kelli
Seattle
Posted: 03/31/12 10:06pm Link  |  Print  |  Notify Moderator
I built a wood frame with four posts that fit down into the rectangular holes at each corner of the truck bed. I then put a thick king sized comporter over the frame and a heavy gauge blue tarp over that. I installed three tiedown hooks on each side of the truck bed and tied the tarp and frame down to the truck bed. I had a futom mattress that fit perfectly into the bed and could get all my stuff and food in the bed of the truck. I had a couple extra boards that I could slide out over the tail gate for cover during rain. This system worked great for a number of years when I was into backpacking. I'd leve the truck for several days and nobody ever touched a thing. A hundred bucks in material and a couple hours of carpentry was all it took. Oddly, I still have the wood frame and the old Ranger but the truck doesn't run and I like my camper better.
Camper Jeff and Kelli's Blog!
A CLOSED MOUTH GATHERS NO FEET!
MKish
SF
Posted: 04/01/12 10:07am Link  |  Print  |  Notify Moderator
Some of the backpacking hammocks are pretty comfy if you're not shy. Of course by the time you add a rainfly and mosquito net...maybe a small tent isn't a bad idea after all. [emoticon]
LoveMyPick-up
Posted: 04/01/12 12:55pm Link  |  Print  |  Notify Moderator
where i am going i am not expecting any rain but i will have a tarp to use as a rain fly if it comes to that. i have decided the small pop up tent is the best way to go for this trip. maybe down the road at some point i will get a real truck tent.
or.... if i ever have a place to keep it.... a shell top. i know alot of people dont mind it full time but... i wouldnt want to drive around with that on if i wasnt camping but it sure would be nice to have.
thanks for all your suggestions. i appreciate it.
mattstorey
Posted: 05/30/12 09:53pm Link  |  Print  |  Notify Moderator
I kinda like this one up! This has to be a very interesting thing to have. If you would want to have all the other options here, try to click here and search up all the things that you might go thru in order for you to get things straight up. Thanks for this one. Really appreciate a whole lot of things here.
* This post was edited 06/03/12 11:44am by mattstorey *
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
