RV.Net Open Roads Forum: Travel Trailers: Leaking Sewer Valve?
 > Leaking Sewer Valve?
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 06/14/12 06:57pm Link  |  Print  |  Notify Moderator
Andy F wrote:
I also have a small water leak around the door seal in a storage compartment so looks like a warranty repair at the dealer will be needed.
You might try tightening up the latch that holds the door closed. Tighten the screw on the end of the lock that holds the latch on the inside. If you can't tighten it up then you can gently bend the latch arm that latches on the inside of the door to the trailer opening to make it a tighter fit. That'll close the door tighter to make it seal better.
I just did that on my trailer on Monday of this week. We had a rain storm on Sunday and I always go around and open up all the storage doors after a storm looking to make sure there's no leaks. I had a little damp spot just inside one of the doors and sure enough the screw was loose on the lock on the inside that holds the latch in place. So I tightened it up and to tighten things up a little more I bent the latch arm in just a little bit to where it takes a little effort now to lock the door with the key. That made the door really snug up tight. We had another rain Tuesday night and I didn't find any more damp spots so I guess that took care of it. I'll keep an eye on it anyway as I always do just in case.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
Andy F
St Cloud, MN
Posted: 06/15/12 09:02am Link  |  Print  |  Notify Moderator
Thanks for the tip! I'll give it a try.
Andy
2012 Keystone Bullet 281BHS
2008 Toyota Sequoia
ProPride 3P - what a hitch!
Nights camped in 2014=33
Nights camped in 2015=39
Nights camped in 2016=31
Our camping photos
More camping photos
Law Enforcement Officer-21 years
Chromag
Posted: 06/18/12 02:10pm Link  |  Print  |  Notify Moderator
So I dropped my TT off at the dealer a week ago today. I just got an email from them that the TT is in the bay and that they've "finally" received a response from Crossroads with regards to the valve.
The dealer is telling me that Crossroads wants them to take out the valve and take detailed pictures of it and send it to them before they'll warranty it.
Is this common?? It's been a full week and the repairs still haven't been done because, according to the dealer, Crossroads is taking their sweet time getting back to them, and then is requiring all kinds of detailed pictures.
2012 Crossroads Z-1 271BH
2004 Nissan Armada with Blue Ox BXW1500, Prodigy P3
HappyTrails2U2
Posted: 06/19/12 07:20am Link  |  Print  |  Notify Moderator
Sounds like a classic case of the manufacture spending a dollar to try and save a dime.
JN_B
Calgary, Alberta
Posted: 06/19/12 07:54am Link  |  Print  |  Notify Moderator
This was an ongoing issue with the valves on my trailer. While I agree it shouldn't be an ongoing problem, with the design on my trailer it is. My trailer has a cable going from the handle to the valve. the cable is about 8-9 ft long, and not secured very well. This allows the cable to flex as I actuate the handle, which means the valve may or may not actually be closing completely. I've gotten in the habit of opening/closing the handle many times after I'm done dumping, and sometimes this works. (I've brought it in on warranty many times for this issue, and they always replace the valve & cable, yet still the same issue).
My only real solution, is to get an additional valve, and place it on as the last fitting for before the cap. This way I know I have no "extras" coming out when I open the cap to put the hose on.
2014 Ford F-150 XLT, HD Payload, Max Trailer
2010 K-Z Spree 318BHS
Chromag
Posted: 06/23/12 09:22pm Link  |  Print  |  Notify Moderator
We picked up the TT today from the dealer. They replaced both black and grey valves (along with a couple other small issues). Everything was covered under warranty and the one small item that wasn't they fixed with no charge. We have a week long vacation planned for the week after July 4th so let's hope this issue is resolved!
Thanks for all the input.
papaquad
Canora,SK
Posted: 07/11/12 08:36pm Link  |  Print  |  Notify Moderator
Wondering how the fix worked for you, I'm having the same issue with my black tank, but my trailer is sitting at a seasonal site until late Sept.
I have notified dealer, but it's a long summer with blue hands...
Randy & Joanne & Cheeko the Blue Fronted Amazon parrot
'11 KZ Spree 323CSS
2005 F150 4x4XLT 3.73
2012 Canam Outlander 800R Max XT-P
2012 Canam Outlander 800R XMR
Chromag
Posted: 07/12/12 06:28pm Link  |  Print  |  Notify Moderator
We're at our second campground of the week and I've dumped the tanks twice and it looks to be fixed. When I open the valve I get a couple drops and that's it.
Just sitting under our awning right now enjoying a cold one [emoticon]
thib2722
Eunice, LA
Posted: 07/17/12 05:59pm Link  |  Print  |  Notify Moderator
It's probably a piece of refuse or paper in the track that the gate slides in. If you can reach it, try scraping gently with a bent wire hanger. That solved my problem once.
Bucky Badger
Madison, WI
Posted: 07/17/12 06:28pm Link  |  Print  |  Notify Moderator
If you do have a leak and don't want the expense or trouble with replacing it you can get a twist on valve to hook on the end of the existing valve for less than $25.00 like the one listed at Camping World.
http://www.campingworld.com/shopping/item/twist-on-valve/27868
Drawback would be the added valve would be exposed outside of the heated and sealed underbelly for those of us with that option on our TT's.
The reason I would not use it, is because it's something else that could go wrong while dumping
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
