RV.Net Open Roads Forum: Tech Issues: Walmart Maxx 24DC Battery _ Seems Good
 > Walmart Maxx 24DC Battery _ Seems Good
cruz-in
Southern Maryland
Posted: 04/03/12 10:52am Link  |  Print  |  Notify Moderator
Hi All,
Just out at my local Walmart, they have a battery labeled Maxx 24DC Deep Cycle for trolling, etc. It is 94 amp hours and has a 2 year replacement warranty. Sticker says it is good for 30% more cycles (than the normal Everstart Marine I assume). Price is $79. In my searching for RV batteries, this one does not look too bad?
Interesting if you go to the website, and search for MAXX deap cycle batteries, the picture is of a MS model (I assume that means marine start?)not the one in the store.
You all's thoughts?
2011 Monaco Vesta
Interesting Coach
This particular one was the prototype.
time2roll
Posted: 04/03/12 11:02am Link  |  Print  |  Notify Moderator
94 amp hours from a group 24 is a deep cycle. Probably the 100 hour rate.
DC 27 is a bit bigger if needed and will fit.
On edit: Actually the 94 would seem to be Reserve Capacity (RC) minutes and not amp hours. Still a deep cycle. Just don't compare the wrong units and expect additional performance.
* This post was last edited 04/03/12 02:53pm by an administrator/moderator *   View edit history
675w Solar pictures back up
cruz-in
Southern Maryland
Posted: 04/03/12 11:06am Link  |  Print  |  Notify Moderator
Thanks the walmart only had Maxx 24DC and Maxx 29DC. I don't think the Maxx 29DC will fit...
* This post was edited 04/03/12 11:12am by cruz-in *
midnightsadie
ohio
Posted: 04/03/12 11:49am Link  |  Print  |  Notify Moderator
before you buy ,look at the date it was made, if older than six months go find another wal mart. or ask when the next shipment is coming in.
cruz-in
Southern Maryland
Posted: 04/03/12 11:52am Link  |  Print  |  Notify Moderator
thanks...good advice
skipnchar
Topeka or somewhere else
Posted: 04/03/12 01:20pm Link  |  Print  |  Notify Moderator
Will probably be better than the EVERSTART but I never got more than about a year out of an Everstart battery. If you dry camp you'd probably be better off with a better battery but if you MOSTLY camp with hook ups the Max will work just fine.
Good luck / Skip
Wherever I happen to park
Posted: 04/03/12 02:59pm Link  |  Print  |  Notify Moderator
It is 73 amp hours, not 94, Wal-mart rates the capacity of the battery at the one amp rate, so it will last 94 hours at that rate.
However for comparison you should use the 20 hour rate, and at that rate it's 73 amp hours.
Other than that. Not a bad battery, just small.
Home is where I park it.
kneal44
EAST CENTRAL TEXAS
Posted: 04/03/12 03:24pm Link  |  Print  |  Notify Moderator
i teamed up a walmart 24 with two sams six gc.
seems to work and is two years old now.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/03/12 05:44pm Link  |  Print  |  Notify Moderator
Charge that battery @ 4 amps for at least 8 hours when you get it home. This excellently conditions new plates, stirs the electrolyte and gets things off to a good start. For the techhies: let the voltage rise to 15 then terminate the charge.
dclark1946
Richardson,TX,USA
Posted: 04/04/12 05:58am Link  |  Print  |  Notify Moderator
100AH is possible from a GR 24. Trojan rates the SCS 150 @100 AH for 20 hour rate. The Gr 27 version is rated at 115 AH.
Dick
Dick & Karen
Richardson,TX
2017 KZ Spree 263RKS
09 F250 V10
