RV.Net Open Roads Forum: Tech Issues: Splendide 2100 timer keeps turning
 > Splendide 2100 timer keeps turning
rrwhistler
N.E. Kansas
Posted: 04/14/12 04:24pm Link  |  Print  |  Notify Moderator
A camper in my park has a strange issue with his washer/dryer. The cycle starts off OK, fills with water, and then starts the wash cycle. However, before it can get too far, the timer starts stepping around like someone is turning the knob.
I think it could be either the timer, or the control module. Does anyone have any insight or other suggestions I can pass on?
Gran & Grump
1994 38' Fleetwood Southwind
Chevy 454 P32
Banks Power
2004 Chrysler PT Cruiser
Kiki, the Boston Terrier(Rescued '02)
Sebastian & Isis, the black cats(Rescued '08)
haddy1
Chesterfield, MO
Posted: 04/14/12 04:31pm Link  |  Print  |  Notify Moderator
I remember having that problem, but I don't remember how I fixed it. Probably just unplugged the unit and reset. I know that I didn't have to throw any parts at it.
2012 Tiffin Phaeton 36QSH
2007 Jeep Wrangler Toad
fantasy islander
Grosse Ile, MI 48138 U.S.A
Posted: 04/15/12 01:38pm Link  |  Print  |  Notify Moderator
Hi,
You have an error code and you need to look up in the manual.
Joe & Cathy Sikora
2010 45' Mandalay Quad Slide, Freightliner XL Tag, 425 Cummins
2003 Blazer 4dr 4X4
Tiny & Ollie
Afghan Hound Rescues
mikestock
Vestavia Hills, AL, USA
Posted: 04/14/12 07:05pm Link  |  Print  |  Notify Moderator
Mine does that sometime if I try to interrupt the cycle it's in. I doesn't like being messed with when it is busy.
katysdad
Virginia
Posted: 04/14/12 08:51pm Link  |  Print  |  Notify Moderator
If the water pump doesn't run when time to drain the tub that will also cause it. You can pull the lower front cover off to access the pump strainer. Might want to have a good wet vac on hand when you open the pump as it will empty the washer if it has water in it.
Dodge Ram 3500 DRW Diesel
ploiselle
South Shore, MA
Posted: 04/14/12 06:54pm Link  |  Print  |  Notify Moderator
The machine has enter it's diagnostic mode. An explanation and the diagnostic error codes for the 2100xc start on page 51.
Training Guide
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
