RV.Net Open Roads Forum: Truck Campers: White particles in water faucet
 > White particles in water faucet
MERC225
Wisconsin
Posted: 04/17/12 03:26pm Link  |  Print  |  Notify Moderator
Hello all,
Last summer I continually found small white particles lodged inside the kitchen faucet head of our camper. The camper was bought new as a 1 year left over in 2009 (camper is 2008). The problem seems not to get any worse, but does not seem to clear up either. It is annoying having to clean the head of the faucet by disassembling it so the stream sprays correctly. I cannot seem to find a cause of this, any ideas?
The water tank has been used a great deal, so doubt it is anything left from manufacturing process. The white substance almost resembles small sand particles, but they are clear/white color.
Dave
2005 Dodge Ram 2500 4x4 Quad cab long box, 5.7 Hemi, Rancho RS9000XL shocks, Rancho MyRide system, Supersprings, Roadmaster rear sway bar.
2008 S&S 9.5 FBSC camper
iwon415
Northern California
Posted: 04/17/12 03:36pm Link  |  Print  |  Notify Moderator
Probably when they cut holes in the tank for sensors, pipes etc, the pieces of the tank fall inward.
I've found similar in the filter to my water pump.
narcodog
Georgia
Posted: 04/17/12 03:39pm Link  |  Print  |  Notify Moderator
Flush your h/w tank. It should be flush at least once a year. I had those white particles in my tank and gave it a good flushing.
NC-Hawk
South
Posted: 04/17/12 04:40pm Link  |  Print  |  Notify Moderator
Check the condition of the anode rod if the hot water tank has one.
narcodog
Georgia
Posted: 04/17/12 05:29pm Link  |  Print  |  Notify Moderator
ecoast wrote:
may also be mineralization
That's what it is.
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/17/12 06:27pm Link  |  Print  |  Notify Moderator
This was my thought as well. Just went through this with the house.
'05 Day Dreamer by Cedar Creek
2011 F250 PSD CC
You can lead a horse to water.
You cannot make it drink.
ticki2
NH
Posted: 04/17/12 03:46pm Link  |  Print  |  Notify Moderator
I had the same and do the same .
'68 Avion C-11
'02 GMC DRW D/A flatbed
ecoast
NW NJ's Highlands
Posted: 04/17/12 03:49pm Link  |  Print  |  Notify Moderator
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
therink
Western New York
Posted: 04/17/12 03:50pm Link  |  Print  |  Notify Moderator
Calcium/mineral build up in water heater. Remove heater drain plug, flush until white particles stop coming out. Do this at least twice/yr.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
MERC225
Wisconsin
Posted: 04/17/12 07:04pm Link  |  Print  |  Notify Moderator
If it is mineralization, what does one do to get rid of it and prevent it? What causes this? This is my first truck camper so I am still learning.
Thanks
