RV.Net Open Roads Forum: Truck Campers: getting leveled, is there a "best way"?
 > getting leveled, is there a "best way"?
Page of 6
synergy_58
Dayton, OH
Posted: 04/19/12 01:20pm Link  |  Print  |  Notify Moderator
I'm out learning my new rig and trying to figure out the best way to get leveled.
It's been suggested that I use these...
http://www.level-trek.com/product.php
What do you use?
With a TC/truck, do I use those stick on levels?
Do I use the jacks to level the truck, thus lifting the load slightly, or is that not the way to do it?
I drove up on a few 2x6's, got the truck slightly leveled but I could still feel that I was dwon too far at the head...this is in my driveway for now.
Any guidance on how you do it is greatly appreciated!
[img/Users/Frank/Pictures/iPhoto Library_2/Originals/2014/Apr 2, 2014/2009_1306_Nav_BlueMoon.jpg[img]
Note: Due to invalid formatting, all formatting has been ignored.
JoeChiOhki
Sauvie Island, OR
Posted: 04/19/12 01:23pm Link  |  Print  |  Notify Moderator
Your camper should have levels on it, if not, it might be wise to get a couple and place them on the camper after getting it perfectly level.
I usually use chopped 2x6s stacked up to drive up onto to level out. I also carry some plywood squares (3/4" thick) as well for when I need less than the thickness of a 2x6.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
bedrocker
lompoc ca
Posted: 04/19/12 01:34pm Link  |  Print  |  Notify Moderator
I put a bubble in the fridge and level
it using lynx leveling blocks [emoticon]
AnEv942
CA
Posted: 04/19/12 01:41pm Link  |  Print  |  Notify Moderator
Use 2 stick on bubble levles on left rear corner-use for lowereing raising camper. At camp-simple wood 2X6s-if needed, carry six to poasition truck. Can sight both direction with levels-if not off loading release tiedowns if needed to levle camper with jacks.
Our camper projects page
d3500ram
Colorado
Posted: 04/19/12 01:32pm Link  |  Print  |  Notify Moderator
I use wood blocks and I have gotten used to surveying the terrain ( seeking the most reasonably level available) and just adding a few under only 1 or 2 tires at the most.
On one instance where I parked the site was less than ideal and I found out how well it did with the articulation of the suspension. I posted here about it: Leveling the camper: suspension articulation & heavy camper. This was by far the most out-of-level site I have parked... but...
...I was amazed at how well it leveled out without "micro-adjusting" the blocks! I like the cheap KISS prinipal of wood blocks...
I have heard that those RV Lego type levelers can break, but I am not knocking them.... just never used 'em.
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
TC-less, previous owner of 2 NorthStar pop-ups and 2 Northstar Arrows.
USMC2010
Arizona
Posted: 04/19/12 01:33pm Link  |  Print  |  Notify Moderator
I tried the stick on levels and did not like them. I take a 6" level with me and place it on the middle of the floor and make my adjustments. This is for dropping the camper which I do pretty much every time. On the truck I have several squares of plywood that I use to drive up on.
2002 Chevy 2500HD LS Extended Cab 4x4 6.0 gas 4.10 rear SWB
Firestone Ride-Rite
Torquelift Quick Disconnect Stableload
2016 Forest River Sandstorm T250SLC
MSgt USMC retired
kerry4951
East Central Pennsylvania
Posted: 04/19/12 02:13pm Link  |  Print  |  Notify Moderator
Heres what I use. They offer varying degrees of lift. I carry 4 of them since I have a dually. On a SRW truck 2 should be fine. They store well in my slide out tray so they are always handy to get at. Never had any cracks or breakage.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
kcabpilot
CA
Posted: 04/19/12 02:23pm Link  |  Print  |  Notify Moderator
I use 2x6's and then the air bags after which I lower the rear jacks for stabilization and can get another inch or so of leveling out of them. For an indicator I open the door halfway and let go. If it stays there I'm perfectly level (or close enough)
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
woodhog
NS
Posted: 04/19/12 07:10pm Link  |  Print  |  Notify Moderator
We carry short pieces of 2x6 , also around here there are always a few rocks you can throw under the wheels, we have a 12 volt DC fridge and don't really pay much attention to leveling.
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow, 3 Batteries 200 Watts Solar,
12 Volt DC Fridge.
dadwolf2
Henderson,NV
Posted: 04/19/12 07:34pm Link  |  Print  |  Notify Moderator
I use the same yellow tri-leveler blocks as Kerry4951 and use a cheap 6" torpedo level. When I'm boondocking, quite often a couple shovels of dirt moved is quick and simple.
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Page of 6
