SJ-Chris
San Jose, Ca
SJ-Chris wrote: Does anyone know if the 2015 Majestic 28a has a CABIN AIR FILTER?
Usually, air filters are located (in cars) behind/under the glove box.
I called one store to ask if they have a cabin air filter for the e450 Super Duty V10 and they said they don't and there might not be one.
Anybody here know? If so, I'd like to change mine as I haven't since I purchased them.
Thanks,
Chris
I heard today from Thor that the 28a Majestic has no CABIN air filter. One less thing to change I guess lol...
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
socal77
Redlands, CA
No insights on my question regarding how to replace the water pump in my 2009 28A I posted a few days ago? Hoping for some guidance on pump model, etc. Thanks!
edited 03/05/22 12:25pm by socal77 *
IAMICHABOD
Sunny So Cal
After looking around on the Forum and on the rental thread I did not find much but looking on another Forum I
Found this that may be of help to you.
Those Former Rentals are tough but sometimes the parts just break,otherwise it sounds like everything is going well,good luck on this.Come on back and share if this is of any use to you so others may be helped.
Former El Monte RV Rental
Buying A Rental Class C
Harvey51
Alberta
After new batteries at Costco the engine would not turn over.
Also a GM van same thing. The batteries says it has 1000 amps but really zero amps and much less than 12 volts.
After 7 months the engine still didn’t start. Damaged the engine ?!
I have both in a good garage and mechanics but they cannot do anything to help.
There is some information on Costco,, asking for more information like year of manufacture and Costco card.
If you find out anything please post it here.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Booner
Boonville, MO
After having my 23A for over a year I thought I would check in.
I haven't had really any negative issues with the RV until recently, and it concerns the house battery. It seems I haven't been giving the battery the love it deserves. CA said they put a new battery in the unit before I bought it, and the battery is a rather expensive battery (Lifeline 100 AH AGM), but since I can't find anything on the battery telling me when it was made, and I suspect that if the battery was "new" a year before I purchased the rv, it probably wasn't charged or maintained as it should have been.
When I first got the rv, I put a number of long trips on it, which should have fully charged the AGM battery. It's only been lately that I think it doesn't hold a charge as it should. But then, how I'm using the rv now has changed, With the cost of gas, I don't make the long trips anymore.
So I think either the battery has seen better days due to the way it's been used prior to my ownership, and/or the way I've been charging the battery hasn't done it any good. For example, I thought that simply driving the rv a long distance would fully charge the battery. No, the alternator will only give it a bulk charge; to fully charge the battery up to 100%, I need to trickle charge it for a couple of days. Who would have thought that?
For a while I've been researching adding solar power to help fully charge the battery. I've learned a ton of information on batteries and solar on the Sportsmobile website. I realize there's information available on various RV sites, but I found that after reading them, they didn't answer all of my questions. On the Sportsmobile site, all of the information I was looking for was in one spot.
the link-->https://www.sportsmobileforum.com/forums/f20/faq-s-battery-problems-and-common-power-calculators-1940.html
Hopefully, this link will help someone discover everything they need to know about how to take care of their house batteries.
SJ-Chris
San Jose, Ca
2015 Thor Majestic 28a - Black waste tank removal and repair...
I just completed a fix on my Majestic 28a. Learned a lot and thought I would post the link here also in case any fellow CA Majestic owners would find it useful or be searching for it...
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30326133.cfm
If you scroll down to the ~10th post there is a complete description with photos/etc
Happy Camping!
Chris
IAMICHABOD
Sunny So Cal
Chris,what a great write up on this,with the pictures and everything.
I will archive this in case someone else may need it in the future.
For any others Here is a Clicky to that 10th post
SJ-Chris
San Jose, Ca
SJ-Chris wrote: 2015 Thor Majestic 28a - Black waste tank removal and repair...
Happy Camping!
Chris
IMPORTANT PREVENTATIVE NOTE: My RV only had 2 brackets in the front edge of the black waste tank holding it up to the underside of the RV. Each of those brackets had places for THREE screws, but they only had TWO screws in each. So, essentially it was being held up by 4 screws. I have since added a 3rd screw to each of those brackets AND added a 3rd bracket on the front edge. You should take a look at what you have on yours and you might want to add some extra screws and perhaps another bracket BEFORE you have this problem and then you can avoid it in the first place! I have another identical Majestic 28a and it also only had 2 brackets with 2 screws on each so I also added more screws and another bracket to that RV as well. I also added 2 additional screws on the rear 2 brackets (there wasn't room for a 3rd bracket).
Good luck!
Chris
