TwistedGray
Monterey Bay, CA
Okay, so I was really excited until I popped the screws off to only find this. I was hoping to get lucky like some of you and find power access so that I can put in a few outlets and run them off the aux battery while in motion. I'm not sure I can do that without running wires directly off the aux battery, unless I'm missing something in this otherwise empty space?
...and yes, I cleaned that dust up really well, and I routed the wiring a bit better than how they had it just laying about.
Edited to add: This is a Majestic 19G, left seat as related to the dinette seating. The right seating area housing the water tank, pump, and wiring, and that has very limited space to do just about anything functional. Maybe you can put a throw blanket down there, but that's about it.
SJ-Chris
San Jose, Ca
Booner wrote: MtnBikeMarty wrote: quasimatter wrote: Thanks Chris for the above answers - Makes sense - I will plan on getting 2 identical batteries.
Another quick question for Majestic 28A owners, What is the compartment in front of Master Bed - It is solid metal box with metal cover screwed on with special pin-in Hex screws. I opened it up and voila - there is nothing in there. Was it supposed to house something? Attaching a picture.
As you can see - there is another metal box inside with sides open (nothing inside that either). Maybe it used to house something which was removed (or an option that was not installed)? It looks a bit odd being right at the foot of the bed and also just being big metal plate which does not match other flooring.
PS: Is there a forum anywhere that is specific to Majestic (or even 28A)?
I remember asking my CA salesman, and he said something about it was an access panel to the transmission, maybe the differential. I just took it at that and never opened it up. Maybe someone else has better information. MtnBikeMarty
I don't know if that access hatch is the same in my unit (23A) as your larger unit, but I was told it was an access panel for the fuel pump.
Enjoy your new toy!
Booner
I was told also that it is access to the fuel pump in the event it needs to be changed. Made me think, "Gee, how often does the fuel pump have to go out such that they design a floor panel like that?"...
-Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
IAMICHABOD
Sunny So Cal 90713
The subject comes up quite often here On The Forum
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
TwistedGray
Monterey Bay, CA
SJ-Chris wrote: Booner wrote: MtnBikeMarty wrote: quasimatter wrote: Thanks Chris for the above answers - Makes sense - I will plan on getting 2 identical batteries.
Enjoy your new toy!
Booner
-Chris
+1
quasimatter
CA
IAMICHABOD wrote: Looking at the picture there seems to be screws in the lower plate,maybe unscrew them and look under it.Inquiring minds want to know... ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I tried already - couple of screws refused to budge and head got damaged. Also the plate it holds seem to be sealed underneath with some black rubber like material - so decided to leave it as it is. But looks like on should be able to store something in there!
quasimatter
CA
Booner wrote: Got Dust?
Since I purchased my former rental, I spend a lot of time on this and other forums trying to learn from others; what problems they have and how they fixed them. I've come to the conclusion that I did the right thing in buying my first RV from CA. Reading the problems buyers have had with their "factory new" motorhomes, people who've spent 3 times what I spent and still have major issues with their new motorhome, only confirms that my decision was the right one.
Thanks for the details and ideas to seal the unit. I also see a big opening next to tire well for the black tank connector (I can see two heating ducts going through same space - one for bedroom and one for bathroom). Would look into sealing that.
I also think it was a good idea to buy CA rental - despite miles, it seems like a solid unit designed in such a way that not much would break. BTW - what are the other forums you recommend?
quasimatter
CA
IAMICHABOD wrote: ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) The subject comes up quite often here On The Forum
WOW - thanks for the link. Some of the horror stories about Fuel Pump issues with E-450s and how expensive it is to getting it replaced (needing to drop the tank etc). If that metal plate/housing indeed to be able to access fuel pump (which seems to go bad regularly on Ford E-450s based on forum links), and given the location of fuel tank right below it - I am 99% sure not that plate opens up over the fuel tank; that would be awesome.
It would make a difference between $1500 job or buying a pump yourself for under $100 and replacing it through that opening! My respect for CA Majestic build has gone higher after reading this. Despite the ugly black plate (we put a rug over it anyway) - reading from other RV owners wanting to cut up the floor to be able to access the fuel pump from the top make me think this is a neat idea and a great foresight of the builder.
socal77
Redlands, CA
Hi Gang,
I'm up in Pismo with my 2009 28A for a couple days. Went to turn on the heater tonight and will not turn on. I think I hear a "click" but the blower doesn't kick on. My propane indicator says 2/3 full and the stove burners work fine. Any troubleshooting suggestions?
edited 12/21/20 10:03pm by socal77 *
IAMICHABOD
Sunny So Cal 90713
socal77 wrote: Hi Gang,
I just saw your post,as you know I don't have the same RV but I would first check and see if your batteries are up and they have a good connection to the furnace,the blower runs on 12 volt.
My next suggestion would be to post this in the Tech Section and ask there,include your make and model of the furnace,I am sure someone will come along with some help.
Good Luck and I hope the rest of the trip will go well.
cencerrita
IAMICHABOD wrote: socal77 wrote: Hi Gang,
Definitly check battery power. I know in the past if overnight whilst boondocking and the power dropped before the sun came up (11.7V) the fridge used to click and then not start.
www.cencerrita.comNow living in Pembrokeshire, Wales, UK. Seeour web site for US travels www.cencerrita.com
