RV.Net Open Roads Forum: Travel Trailers: Rear Framing
 > Rear Framing
chimeraxp
calgary
Posted: 05/10/12 11:58am Link  |  Print  |  Notify Moderator
OK the PO "repaired" the rear section of the trailer but a nightmare is what is really is ....could be worse .
The rear section has a single large window under this he sheeted the lower section of the trailer with plywood (33"x84"). leaving it exposed to the weather . looking around seems the lower framing is all removed , he had the sheet screwed in to the benchs and corner framing.
after opening the inside I found bother corners rotted almost floor to ceiling .
Yesterday I opened everything up out side . replacing the two corners.
Now I think it would be best for me to re-frame the back , removing the sheet of plywood and tin the out side ..
so anyone have some pictures showing the framing of the rear with a single window .
Once I figure out how to post pictures I'll upload what I can.
Gene&Ginny
North Kingstown, RI
Posted: 05/10/12 06:25pm Link  |  Print  |  Notify Moderator
It may be helpfull to know what brand, model, year trailer you have. I don't think all manufacturers build things the same way.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
chimeraxp
calgary
Posted: 05/10/12 09:30pm Link  |  Print  |  Notify Moderator
leaning towards Tripe E unsure on what year .
been having a hard time all day posting . will try and get pictures uploaded later
Gene&Ginny
North Kingstown, RI
Posted: 05/11/12 08:32pm Link  |  Print  |  Notify Moderator
Here is a picture from a fellow Sunline owner when he rebuilt the rear of his unit. If all you had in the back was a sheet of plywood then you may have to design your own "rebuild". Some framing is hard to see with the insulation. His rebuild was mostly under the window where there is no insulation in the picture.
chimeraxp
calgary
Posted: 05/11/12 10:56pm Link  |  Print  |  Notify Moderator
thanks for the post , a good picture too ! should help me out a lot .
hilandfrog
Montana
Posted: 05/11/12 11:40pm Link  |  Print  |  Notify Moderator
NOT trying to pimp a thread but.....
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25467063/srt/pa/pging/1/page/3.cfm
lots of pics....
Good luck
Repo
05 Tundra 4x4
1976' SIX PAC, cut to size and function.
$800 1977' Road Ranger, not yet road worthy (AUG '11')
chimeraxp
calgary
Posted: 05/11/12 11:49pm Link  |  Print  |  Notify Moderator
Try this , more or less the current state .
thanks for the link too
Gene&Ginny
North Kingstown, RI
Posted: 05/12/12 08:20pm Link  |  Print  |  Notify Moderator
lots of pics....
xxx
Good luck
Repo
Yes, that is a good thread and some great pictures, deserves to be a "clicky".
http://www.rv.net/forum/index.cfm/fuseac........d/tid/25467063/srt/pa/pging/1/page/3.cfm
Gene&Ginny
North Kingstown, RI
Posted: 05/12/12 08:24pm Link  |  Print  |  Notify Moderator
chimeraxp, looks like you have quite a project ahead of you. Good luck on the rebuild.
Downwindtracker2
BC
Posted: 05/13/12 10:33pm Link  |  Print  |  Notify Moderator
I haven't tackled a TT,just a tent trailer,new roof,front and floor. There are a couple of tools for putting it back together that are really handy, Kreg pocket hole jig,Lee Valley or KMS and a narrow crown air stapler,Princess Auto or KMS. Good luck.
Adventure before dementia
 > Rear Framing
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
