RV.Net Open Roads Forum: Buying a South Carolina Boat Trailer, no title no plate??
Search only in Towing
Open Roads Forum  >  Towing
 > Buying a South Carolina Boat Trailer, no title no plate??
LoveTwoCamp
Arcola, Pa
Posted: 05/15/12 05:55pm Link  |  Print  |  Notify Moderator
I am thinking of buying a boat and trailer from South Carolina. However, the seller states that SC does not require a title, or plates, on boat trailers, so he has neither.
It is too late today to contact Pennsylvania DMV, so I thought I might try for some insight from the RV group.
I have never heard of trailer without a title; is this normal in SC?
If this correct, how does one get a title for Pennsylvania?
Any other words of wisdom?
--The boat does have SC numbers on the bow.
END: After a lot of phone calls, I cannot get the trailer titled in Pa without a proper title or SC registration card stating that the trailer is a "Non Titled Trailer". But he can't get that card without a title. I told him, No Title, NO DEAL! Have to look for another boat.
* This post was last edited 05/16/12 02:06pm by LoveTwoCamp *   View edit history
og
2000 Holiday Rambler AlumiLite 28'
2004 Silverado 2500HD, 4X4, Crew Cab, Duramax/Allison
Reese Dual Cam
Two 6 Volt Batteries with Control Switch
Prodigy Controller
1995brave
San Antonio, TX
Posted: 05/15/12 06:04pm Link  |  Print  |  Notify Moderator
Try and find the SC DMVon-line and see if you can find their requirements for titling a boat and trailer. If nothing else the boat probably needs to be registered and have a set of numbers and letters on it's bow.
the_happiestcamper
Mount Pleasant, SC
Posted: 05/15/12 07:21pm Link  |  Print  |  Notify Moderator
In SC, a boat has to be registered before it goes on the water - you can tow one that is not registered. There is no title or plate for trailer.
If you wanted to buy a boat in SC, I would have gladly sold you mine [emoticon]
Me ('62), DW ('61), DS ('97), DS ('99), DD ('03)
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
KD4UPL
Swoope, VA
Posted: 05/15/12 07:22pm Link  |  Print  |  Notify Moderator
I would tend to assume that a trailer with out a title is stolen. Even if SC doesn't require a title the trailer should have had one to begin with.
But, I live in VA where everything with wheels requires a title and tags.
Francesca Knowles
Port Hadlock, Washington
Posted: 05/15/12 08:06pm Link  |  Print  |  Notify Moderator
This isn't an uncommon situation- many States don't require title/registration for trailers under a certain size, and others don't even title truckcampers.
BUT
When you bring a trailer into a State that requires titling, that's when the problems start.
In my State, what you'd need would be the "manufacturers certificate of origin" which comes with every commercially produced trailers. I'm betting that the same is true in Pennsylvania. If the seller is the original owner, he/she might still have that.
If so, that and a bill of sale should be enough to get you on the road in Pennsylvania.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
W4RLR
Sewanee, Tennessee
Posted: 05/16/12 01:13am Link  |  Print  |  Notify Moderator
Florida doesn't issue titles for utility trailers. Tennessee accepted my trailer registration from Florida and issued a Tennessee title and plate. No problems, no hassles. It depends on the state's requirements.
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2008 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?"
Tom Clancy
mowermech
Billings, MT
Posted: 05/16/12 08:41am Link  |  Print  |  Notify Moderator
The best bet is contact the Motor Vehicle Department in PA, explain the situation, and they should be able to tell you exactly what you need to do to get the trailer licensed in PA with no title from the former owner.
Here in Montana, I could remove all identification from the trailer, state that it is "Home-Built", and the state will issue a VIN to me, I stamp that on the trailer, have it inspected, and the State will issue a title for a 2012 "HMDE" trailer.
Maybe PA has the same or a similar program for home-built trailers.
CM1, USN (RET)
Daily Driver: '14 Subaru Outback
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
Francesca Knowles
Posted: 05/16/12 10:35am Link  |  Print  |  Notify Moderator
Here in Montana, I could remove all identification from the trailer, state that it is "Home-Built" , and the state will issue a VIN to me, I stamp that on the trailer, have it inspected, and the State will issue a title for a 2012 "HMDE" trailer.
Um...the "chop shop" approach, eh? Bet Montana has about a "zero recovery rate" on stolen trailers...
Note to self:
Double up security/insurance on trailer if headed to Montana!
To the O.P.:
Many States require records of the provenance of the parts used to make a home-built trailer, and will inspect them carefully before issuing a Title. I recommend extreme caution before venturing down that slippery slope.
As others have said: Check your State's rules!
mowermech
Billings, MT
Posted: 05/16/12 12:19pm Link  |  Print  |  Notify Moderator
"Um...the "chop shop" approach, eh? Bet Montana has about a "zero recovery rate" on stolen trailers"
I wouldn't know, I rarely hear anything about stolen trailers of any kind around here. Apparently, there is no money to be made by stealing them.
Actually, my horse trailer is a 2002 HMDE trailer, according to the title and registration. It is quite obviously a commercially built 2-horse trailer, circa 1970.
johntank
North MS
Posted: 05/16/12 04:20pm Link  |  Print  |  Notify Moderator
Might ask if he has the MSO for the trailer in his paper work, if he does it should not be a problem to get it registered and titled in Pa.
