RV.Net Open Roads Forum: Tech Issues: Smoke Detector & Carbon Monoxide Detector
 > Smoke Detector & Carbon Monoxide Detector
JanVanDen
Southern Maryland
Posted: 05/23/12 03:01pm Link  |  Print  |  Notify Moderator
They are both the original ones that came with our 2007 Puma... We have replaced batteries yearly. OK, so this year one started to beep I think it was the CM Detector. We bought new batteries for both and they are chirping with new batteries.. Am I doing something wrong or is it time to replace the units...
Thanks
Janet
Oasisbob
Portland Oregon 97266
Posted: 05/23/12 03:05pm Link  |  Print  |  Notify Moderator
Could just be old batteries that sat on the shelf a bit too long. Easily checked with a volt meter.I have originals in my 01 HTT .
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 05/23/12 03:10pm Link  |  Print  |  Notify Moderator
Carbon monoxide detectors should be replaced every five years. That may be the problem.
2017 Keystone Cougar 29RES, 2008 F250 Diesel FX4
Fire Instructor
Upstate (Albany) NY Area
Posted: 05/23/12 03:36pm Link  |  Print  |  Notify Moderator
The CO detectors oxygen sensor will die in most lower end units withing 5 or 6 years, and will alarm to false positives. You should get more life out of the smoke detector, but since you can purchase a battery operated smoke detector for mless than $10, I wouldn't mess around with none that you felt was malfunctioning.
Fire Instructor
2014 Ram Laramie w/6.7L Cummins Diesel with Automated Safety Hitch
2016 Jayco 377RLBH
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
Eycom
32043
Posted: 05/23/12 03:37pm Link  |  Print  |  Notify Moderator
Ditto
RVn Full-time
othertonka
Stockton, CA
Posted: 05/23/12 05:17pm Link  |  Print  |  Notify Moderator
Look at the inside or back of the detector for a manufacture date and also for a life expectancy date. On a 2007 RV the detector could hve been made in 2006 so that is going on 6 years. My detecor false alarmed right at 6 years, so I just replaced it.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
mike-uswest
Central Point, OR, USA
Posted: 05/23/12 05:20pm Link  |  Print  |  Notify Moderator
That noise can drive you crazy after awhile.[emoticon] Time to get a new one.
Mike
2003 Dodge 2500 CTD, 4X4,
Arctic Fox 25Y
dalenoel
S.E. Michigan
Posted: 05/23/12 06:54pm Link  |  Print  |  Notify Moderator
My CO detector just went bad in the S&B 3 months after the 5 years since manufacture. I talked to the manufacturer and they don't like the unit being in a RV over the winter or storage in extreme heat as that will shorten the life. It does not matter that it is not in use but just that the sensor has a life expectancy.
I bought a new unit at Wally World and opened it right away and found out it was already two years old and took it right back. The manufacture said to let them know, Walmart, to rotate the stock more often.
The unit I have is from Kidde.
03 Monaco 36PBD DP - 06 Malibu Maxx Toad (SOLD) 18 Focus Toad
08 Jayco Eagle 322FKS (SOLD)
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Tracking campgrounds with Ultimate Campground Log
IAMICHABOD
Sunny So Cal 90713
Posted: 05/23/12 07:23pm Link  |  Print  |  Notify Moderator
All the newer smoke and CO detectors go bad at about 5 to 6 years and start chirping, mine in my motorhome did after 6 years most have a date on them and it is prudent to replace them. Better safe than sorry or not wakeup at all. Kidde makes a new Night Hawk that is compatable for RV and boats.It detects all kinds of fires and CO. Most Rv fires start in the wireing and smolder this one will detect that too.I researched til my eyes bled,and this one is the best I could find. Just passing along the info. It is up to you to decide.
* This post was edited 05/23/12 07:45pm by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
path1
Varies with weather
Posted: 05/23/12 07:24pm Link  |  Print  |  Notify Moderator
We have had some battery problems, Digging through old reciepts wife found paper (amoung other junk) the paper was tltled:
C/M & propane alarm replacement notice. Said exactly that. All Safe-T-Alert (bla bla).. that are 5 yrs old and older are beyond their Mandatory Replacement time and must be replaced. Along with blank form that looks like we supposed to fill it out and send back in when we bought it. Form says that says basically if we don't replace the alarm it is their not a fault for anybody's death.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
