RV.Net Open Roads Forum: Fifth-Wheels: Rockwood Signature Ultralite caulk problems
 > Rockwood Signature Ultralite caulk problems
gparrow
Morgan City, LA
Posted: 06/01/12 11:13am Link  |  Print  |  Notify Moderator
Our 2010 Rockwood 8280ws has always had a problem with the caulk cracking (pulling apart) on both front sides where the seam on the chin from the front cap back 12-18 inches. Every service center i've taken it to has dad a different answer as to what is causing the stretching and cracking of the caulk. They inspected the hitch welds and found nothing wrong with it, Watched it durring a test drive to see if there was any bouncing durring travel and said it looked ok. I stopped by a Rockwood dealer last weekend and noticed that every new 2012 Rockwood fiver they had on the lot had the same cracks in the same place. When I asked about it I got the standard answer that they just need to be professionally re-caulked every six months as part of normal preventative maintenance. To me it seems strange to see 10 brand new rigs sitting in a row on a dealers lot with the same problem. I'm not talking about one small tear on each side, the caulk is separating a good 12-18 inches back from where the botton of the fron cap meets the seam on the bottom of the chin. Has anyone else noticed this and gotten better answers than me?
mapguy
Puget Sound
Posted: 06/01/12 12:39pm Link  |  Print  |  Notify Moderator
Structure flex plain and simple. Eternabond tape might be a better solution long term.
fivecodys
Central California
Posted: 06/01/12 03:26pm Link  |  Print  |  Notify Moderator
I basically have the same trailer as yours (different stickers)
I have the exact same problem you described.
It has been that way from day one.
I think it's because of the flexing.
I also pull back the white rubber strips, that hide all of the screws, and tighten them now and then.
Last fall I re-caulked the starboard side of the rig myself.
I stripped off everybit of caulking that I could and cleaned the area with mineral spirts before I applied the new stuff.
So far it is holding.
I used DiCor Lap Sealant. I ordered it from Amazon.com
Good luck,
Bill
2007 Tundra DC 5.7L V8
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS Ultralight Series
Air Lift 5000
We have enough youth.......... how about a fountain of "smart"? ">
TWO 4 THE ROAD
MURRIETA,CA
Posted: 06/01/12 04:05pm Link  |  Print  |  Notify Moderator
Gparrow: Yep,, I've got the same prob with my Flagstaff/Forest River 5er. The Caulk around the front cap keeps cracking and falling off in places. I too have contact Forest River and got the same answer, which was of no help at all. I re-caulk this area about every year, clean the old stuff off tighten the screws and re-caulk. It lasts about 5 or 6 months before it starts up again. I guess it's just one of the things that make Rving interesting as well as irritating...
good luck.
07 Forestriver Flagstaff 8528GTSS, 07 Chev,2500hd, D/A, , 2000 Mitsubisi Eclipse. ,DW Kathy,DD Maggie
gparrow
Morgan City, LA
Posted: 06/01/12 09:27pm Link  |  Print  |  Notify Moderator
Thanks for the replies everyone, we plan to keep this one for a while so I get nervous about these things. I did'nt think about checking the screws so I'll add that to my list.
Greg
RVhiker
Posted: 06/02/12 06:29am Link  |  Print  |  Notify Moderator
I store my trailer at a dealer's lot. I've seen a lot of fifth wheels on the lot that are awaiting repairs for water damage in this area.
1) Do all caulks last about the same in this area, or is there one that is superior? I can say that the Proflex I applied about lasted about 2 months before cracking and splitting.
2) I saw posts on this forum from a guy who used Eternabond strips in this area. Does anyone know how the Eternabond lasted in this use?
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
mwebber78
New England
Posted: 06/02/12 07:05am Link  |  Print  |  Notify Moderator
Just a thought, but the chance of water damage is determined by whether or not putty tape was applied under that metal strip. If this was a constant area with caulk splitting I would remove all the caulk and remove the trim strip for inspection.
Eternabond makes a micro-seal tape that will not ooze or break down like normal butyl tape. I would clean all old sealing materials from the unit and the strip, apply the micro-sealant, re-install, and finish with a bead of Dicor non-sag lap sealant. The Dicor flexes better than the Proflex on moving joints.
The benefit of the micro-sealant is that when the caulking cracks again you KNOW there is no water entering the strip. I personally wouldn't apply the white Eternabond strips to that area, just for the visual and resale value issues.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
gparrow
Morgan City, LA
Posted: 06/02/12 09:45am Link  |  Print  |  Notify Moderator
1. Nothing i have tried has lasted longer than a month or two, A guy at a service center in Illinois recomended to try Quad caulk from Home Depot as it's supposed to have the most stretch but it's only been a couple weeks since i got it on the rig so can't say how long it'll last yet.
2. Personally I'd rather stay away from Eternabond it this area because as stated above it's gonna stick out like a sore thumb.
ferretgrandpa
Missouri
Posted: 06/03/12 03:55pm Link  |  Print  |  Notify Moderator
Had the same problem with our Flagstaff. Dealer could not fix, so I sent it to private repair shop. Had them pull the front cap and check things out. One side of the aluminum frame was NEVER bolted down. He bolted it in, reinstalled the front cap and recaulked. Been good for 2 years now.
98 GMC 2500
RBW Lil Rocker 15K
08 Flagstaff 8526 RLS
johnb83
california
Posted: 07/09/12 10:36pm Link  |  Print  |  Notify Moderator
We had the same problem with our 06 rockwood 5th, unhitch and the molding would drop down about 1/4 inch. I contacted Rockwood who gave me a " fix" for the problem. The work had to be done at a shop it involved pulling the cover off the area around the pin box then installing lags through the steel frame into the sidewall. It's funny Rockwood had a fix all ready to send!! The bad news is this fix did not last a year.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
