RV.Net Open Roads Forum: Using two Power Outlets at CS? Any problems?
 > Using two Power Outlets at CS? Any problems?
RusLwt001
Dacula, GA
Posted: 06/25/12 07:41am Link  |  Print  |  Notify Moderator
When we hook up at a site, I obvioulsy use the 30Amp outlet on the site. However, whenever the DW uses her hair dryer we have to turn things off, sometimes the AC to keep from flipping a circuit. Then it just gets too hot inside without the AC. My thought is that I run a separate power cord from the 110 outlet on the site to the bathroom in the TT. The outside shower opening is right beneath the bathroom sink. This way she can connect the Hair dryer to that cord and hopefully continue to run the AC inside the TT. Does anyone see any problems with this idea? Is drawing 30Amp and 110 at the same time from the same site outlet going to cause any problems with the 30AMP or my TT electrical system? I would appreciate your help. Thank you.
2012 Shadow Cruiser 285RLS
Russ
2012 Ram 1500 V8 5.7 Hemi
jdkd123
Northeast
Posted: 06/25/12 07:49am Link  |  Print  |  Notify Moderator
I put in a recepticle just for that purpose. I carry a 12 gauge, 25' extension cord that connects to the RV and that then connects to 2 inside plugs. DW uses it for the hair dryer. It has worked really well. I did run it through a GFI breaker too.
JDKD123
2005 Coachmen CONCORD
GO SOX!
jyh818
Chino, CA
Should be no problem at all. I did just that once in Las Vegas in 117 degree temp.
We got a stand alone AC unit inside the trailer. Ran an extension cord through the side of the slide out and plugged in to the 15A outlet on the post.
With both AC blasting, we were able to get the temp inside the trailer to 96 degrees. Still way too hot, but the portable AC did as advertised. Drop 20 degrees below ambient temp.
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
Prodigy Brake Controller
EAZ-Lift WD Hitch
chuggs
Posted: 06/25/12 07:55am Link  |  Print  |  Notify Moderator
If the pole has a 50amp outlet as well...you will be able to do exactly what you are planning. The pole is usually wired with 2 legs of 50amps each... The 30 amp outlet is on one leg...the 20amp outlet on another...so with an extension cord running to the 20amp outlet...that hair dryer can go full tilt and not take anything away from the 30amps that your RV is using.
If you are connected to a pedestal that only has a 30amp and 20amp outlet...then it depends on what the electrician used to supply it. If they only used a 30amp supply...then you'll run into tripping breakers...
I put a pedestal in my yard...and elected to run 80 amps to it... I can theoretically run a 50amp rv, 30amp rv, and a 20amp GFCI outlet all at the same time [emoticon] I don't plan to do that...I did it more in case I want to plug my tig welder in outside. It will make it easy to temporarily swap breakers to avoid nuisance trips when welding.
RoyB
King George, VA
Posted: 06/25/12 07:56am Link  |  Print  |  Notify Moderator
I do it all the time.... I just run an extension cord into the trailer and run what ever I need it for. The 20AMP pedestal circuit has its own circuit breaker so wont trip the 30A trailer breaker...
The high current things like you mentioned including electric heaters and vacuum cleaner etc can be plugged into the 20AMP circuit.
I carry extra extension cords just for these kinds of things that come up...
Some high profile camp sites may have meters on there pedestals but most others do not...
Its interesting at Westmoreland State park here in VA. they have tent camper pads mixed in with the Rv pads... Some have Electric and Water and some don't... After a day when everyone arrives you see all kinds of cords running all over the connecting areas where lots of tent campers realize there is electric close by and hooks in haha...
I would use what I needed unless there is a sign saying otherwise...
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
RusLwt001
Dacula, GA
Posted: 06/25/12 08:27am Link  |  Print  |  Notify Moderator
You know, this is the best forum for answering questions. Thank you all. I just wasn't sure, but now I feel a lot better. I like the idea of hooking up a GFCI outlet; however, how do you do that without cutting the wires in the extension cord? I think I can see this in my mind, but it just isn't there. Do I connect to outlets to each other; one to receive the input and then one to output the power? Or, do I just plug the cord into one of the outlets and it provides power to the other? Obviously not an electrician so these ideas probably sound kinda strange, huh?
oakmandan
Iowa
Posted: 06/25/12 10:05am Link  |  Print  |  Notify Moderator
I've done that many times when camping where it is very cold. I run 2 ceramic heaters. One hooked up to indoor outlet, one with cord to outdoor 110.
Dan and Diann
Sherman the smelly Basset
2016 KZ Durango 1500. Model 281RLT
2009 Ford F-250
westend
Shorewood, MN
Posted: 06/25/12 10:17am Link  |  Print  |  Notify Moderator
There are more than a few ways to enable the connection between TT and pedestal with GFCI on the trailer end. 1)Buy an extension cord with the GFCI built in. 2)Direct wire a cord from an installed GFCI receptacle on the TT 3)Install a power inlet on the TT and use the specific cordset to connect to the pedestal. The wiring from the power inlet should have a circuit breaker and downstream wiring of a GFCI receptacle can be done. 4)If the pedestal has a 20 amp GFCI receptacle, any device powered by an extension cord would also be protected-do nothing.
Hope that helps.
'03 F-250 4x4 CC
rgolding
Southern Illinois
Posted: 06/25/12 12:13pm Link  |  Print  |  Notify Moderator
WE have a secondary circuit to the trailer, purely for the ceramic heater or the hair dryer. Works great! It hooks into the GFI on the campground power pedestal, but I have a conversion plug that it could be hooked to the 30 amp or 50 amp circuits.
Smooth Sailing,
Ric and Jan
Southern Illinois
2016 Jayco Seneca 37FS "Low Key"
jdkd123
Northeast
Posted: 06/25/12 01:08pm Link  |  Print  |  Notify Moderator
Russ-
I put this connector on the outside of my RV to accept the female end of an extension cord from the post. From this, I ran wire to two dedicated recepticals inside. This is a Marinco brand plug with a watertight cap.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
