RV.Net Open Roads Forum: Technology Corner: Bedroom TV not working
 > Bedroom TV not working
ford truck guy
Pennsylvania
Posted: 06/27/12 04:52am Link  |  Print  |  Notify Moderator
Hi all ,
I was hoping some of you AV guys could help me out....I believe my TV splitter box is bad ?? When on Air antenna my down stairs TV is fine...my TV in the bedroom gets ZERO channels.. i tried swapping around the wires and was able to get 4 stations up stairs while I was getting 10 or so downstairs.. There is a JUMBLE of wires behind there and none of them are marked??And on the 2nd TV side of the box , there are 2 different wires coming off both with splitters going to 2 more each HELP !!!
Me-Her-the kids
2015 Ford F350 SD 6.7
2016 Redwood 38RL Black~Silver
wilanddij
CA Desert
Posted: 06/27/12 07:14am Link  |  Print  |  Notify Moderator
Has the BR TV ever worked OK?
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Ford C-Max/Blue Ox
"We have met the enemy, and he is us" Pogo
ford truck guy
Pennsylvania
Posted: 06/27/12 02:01pm Link  |  Print  |  Notify Moderator
never on air... I bypass the box completly and all is good...I believe either a wire is crossed,,, the box is bad,,, or the wire is bad running from box to TV ?..
wilanddij
CA Desert
Posted: 06/27/12 03:51pm Link  |  Print  |  Notify Moderator
Best way to tell whether its the box or the installed coax is to run a separate coax from the box directly to the BR TV.
ford truck guy
Pennsylvania
Posted: 06/27/12 08:08pm Link  |  Print  |  Notify Moderator
***UPDATE***
on the advise from Shortlance over on KZOwners forum , i picked up 2 new digital splitters and replaced the 2 factory installed splitters.. All is good !! Fired up the TV's and had 45+ digital stations from the antenna on both TV's...Joe
schneid
In the Wind
Posted: 06/28/12 02:10pm Link  |  Print  |  Notify Moderator
Interesting
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
