RV.Net Open Roads Forum: Tow Vehicles: Mileage on new GMC Duramax/Allison
Search only in Tow Vehicles
 > Mileage on new GMC Duramax/Allison
ksss
Eastern Idaho
Posted: 06/28/12 10:47am Link  |  Print  |  Notify Moderator
You have a great tow rig. My experience with the DIC on my GM trucks has always been within a couple tenths either way of actual hand calculated.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2015 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
bgum
South Louisiana
Posted: 06/28/12 11:02am Link  |  Print  |  Notify Moderator
You milage will improve after about 15000 miles. My milage got worse with winter blend fuel.
4x4ord
Canada
Posted: 06/28/12 11:27am Link  |  Print  |  Notify Moderator
I check my "fuel used" meter on every tank and find it to be within 1%. I have checked the odometer against 5 km test sections on the highway and found the truck actually goes 5% further than what the odometer is saying it went. (that is with the original tires which are getting quite worn - so new tires could put it out another 2%) The real strange thing is that the speedometer is out the other way according to Garmin. And even stranger yet is the fact that the Ford has an engineering test mode that can be entered on the DIC. In this mode a digital display of mph is given which does not coincide with the speedometer.
2016 F350 SRW Platinum short box 4x4.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
nevadanick
Elko, Nevada
Posted: 06/28/12 02:25pm Link  |  Print  |  Notify Moderator
Kinda arrogant saying the meters are off without knowing for sure isn't it ?
gmcsmoke
Butler
Posted: 06/28/12 02:39pm Link  |  Print  |  Notify Moderator
This is RV.net where the experts think they know everything and are proven to know nothing.
Beaker
Brevard, NC
Posted: 06/28/12 03:43pm Link  |  Print  |  Notify Moderator
Strange how hand calculated can never be off! Has to be the DIC.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
xaugievike
Chicagoland
Posted: 06/28/12 03:54pm Link  |  Print  |  Notify Moderator
the DIC on my '06 has generally been pretty accurate....from spot-on to a variance of +- .2 mpg's.
2015 Chevy Silverado 3500hd DRW.
Pulling Keystone Cougar 325SRX
A buddy and I started a blog - you can read it here:
http://twoguyscamping.blogspot.com
nevadanick
Elko, Nevada
Posted: 06/28/12 04:31pm Link  |  Print  |  Notify Moderator
From some of the mileage claims on here i would have to disagree with the hand calc being accurate
jalichty
Lander, Wyoming 82520
Posted: 06/28/12 05:20pm Link  |  Print  |  Notify Moderator
I just did a hand calc this afternoon and, if the usage of fuel is correct and the miles on the trip are correct, then I got just over 13 mpg. The DIC showed 12.9 at the same time. I would have to assume that the DIC is fairly accurate based on this. I had the same situation on my old 2003 GMC and, until I changed out to bigger tires, was spot on. After I got the bigger tires, only 265s from the old 245s, there was as much as 2.5 gallons difference, always showing better mpg than actual. Didn't reset itself when I put 245s back on it later.
John A. Lichty
Beaker
Brevard, NC
Posted: 06/28/12 07:00pm Link  |  Print  |  Notify Moderator
Mine is also very accurate.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
