RV.Net Open Roads Forum: Tech Issues: Transmission would not go into gear.
 > Transmission would not go into gear.
BrucePerry
Cornwall NY
Posted: 06/29/12 10:47am Link  |  Print  |  Notify Moderator
Never had this happen before. Drove the motorhome for about 300 miles, and made a stop at the rest area. When I started the mh back up, I disengaged the air brake, and hit the D button on the gear selector. The only thing that happened was the "6" blinked, and the "N" stayed solid. I have an Allison 3000mh tranny. I tried it a couple of times, then decided to turn off the rv and restart. Tranny worked fine after that, but I did see the service light (wrench) show up for a split second when I put into gear. I did make it to my destination with no other problems, but have a 400mile trip to get home in a couple of days. Figure I will have it looked at when I get back, but for now is there anything I should do or check?
beaverpusher
stanwood washington
Posted: 06/29/12 10:52am Link  |  Print  |  Notify Moderator
I see no mention of checking the transmission fluid level.
RV'S and Hot Rods with a little fishing once in a while.
Denny's toys
1990 Beaver Contessa 36'
1999 jeep
19.5' Bayliner
1938 ford streetrod
1966 Ford Mustang convertable
1965 ford mustang coupe
Retired US Air Force 1968-1990
Stanwood Wa.
naturist
Lynchburg, VA
Posted: 06/29/12 11:36am Link  |  Print  |  Notify Moderator
Totally unfamiliar with that rig or tranny, but fluid level would be my first guess, too. That's pretty common with automatic transmissions.
RognBon
Roseville, Calif.
Posted: 06/29/12 12:26pm Link  |  Print  |  Notify Moderator
Had this same thing happen to me. The display showed a service code that indicated the idle speed of the engine was too high for the transmission to engage. I shut the engine off and restarted, then let it run for a couple of minutes. I pumped the pedal a couple of times and the idle speed dropped to normal and everything was fine. Has never hapened again.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
wolfe10
Posted: 06/29/12 03:46pm Link  |  Print  |  Notify Moderator
Yup, my first thought too.
If engine idle speed it too high, the transmission will not (and should not) go into gear.
Have you used the up/down arrows to check for Diagnostic Codes? Takes 2 minutes from driver's seat using Allsion shift pad.
http://www.allisontransmission.com/servl........publications/pubs&FileToGet=SA3360EN.pdf
Brett Wolfe
2003 Alpine 38'
BrucePerry
Cornwall NY
Posted: 06/29/12 04:00pm Link  |  Print  |  Notify Moderator
thanks for the info. Im going to check the fluid level, I figured I would have had a message displayed for that since the computer seems to flash messages that are less important (such as def fluid temp too high). I will post after I check the levels and I will check for the Diagnostic codes (though after reading through the book I see that unless something major, there may have not been a code)
BrucePerry
Cornwall NY
Posted: 06/30/12 07:53am Link  |  Print  |  Notify Moderator
Follow up: Fluid level is good.
BrucePerry
Cornwall NY
Posted: 07/01/12 06:03pm Link  |  Print  |  Notify Moderator
Drove 375 miles home today, no problems. So I'm guessing Rpm too high. I will drop off to repair shop this week and see if they find anything.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
