RV.Net Open Roads Forum: Did everybody but me know this cooking tip?
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Did everybody but me know this cooking tip?
CA POPPY
Santa Clarita, CA, USA
Posted: 07/01/12 07:53pm Link  |  Print  |  Notify Moderator
I'll bet you all did. Last week an email was going around titled "Why didn't I think of that?" It was handy household hints and one of them was, "To keep a pot from boiling over, lay a wooden spoon across the open top." I tried it as I am always having something boil over, even though I have those little ceramic discs supposed to prevent it. Well, the wooden spoon (unvarnished, of course) works like a dream! Food cooks faster because somehow the heat stays in the water, but no bubbling over, not even close! I totally do not understand the physics behind this, but I'll bet it is an old, old concept. If my grandma knew it, she never told me. [emoticon]
Judy & Bud (Judy usually the one talking here)
Darcy the Min Pin
2004 Pleasure-Way Excel TD
California poppies in the background
campinginthewoods
Central ILL
Posted: 07/01/12 07:57pm Link  |  Print  |  Notify Moderator
I spray pam around the top edge of a pan and no boil overs.
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
Beartoo
Perham MN
Posted: 07/01/12 08:07pm Link  |  Print  |  Notify Moderator
Did not know that butI am going to try it, Thanks!
DH - Bear
DW - Marge
Buster - English Springer Spaniel
Molly - English Springer Spaniel Puppy
07 Silverado 2500HD, Dmax, Allison Trany
Husky 15K
2008 Wildcat 24RL (Old Camper)
2009 Open Range 280 RLS (New)
Desert Captain
Tucson
Posted: 07/01/12 08:35pm Link  |  Print  |  Notify Moderator
I always add a couple of drops of Olive Oil (vegetable works fine too), as this changes the surface tension of the water and no boil overs.
SWMO
Southwest Missouri
Posted: 07/01/12 09:47pm Link  |  Print  |  Notify Moderator
I know about the oil or Pam trick and why, but hadn't heard the spoon trick.
The reason oil works is because the bubbles need to climb on something. It's the same reason you have to be careful about heating water in a micro wave.
2009 Dodge 3500 Laramie, DRW, 4X4, auto, 6.7L, B & W Companion.
Jayco Designer 34RLQS, Mor/Ryde
JayWalker2009
I'm not really a
Posted: 07/01/12 09:51pm Link  |  Print  |  Notify Moderator
I did not know that. But I have always put olive oil in the water and have had no issues with boiling over.
CA POPPY
Posted: 07/01/12 09:58pm Link  |  Print  |  Notify Moderator
I've done the oil thing for years, but invariably it aerosolizes and a fine mist gets on cabinets and other surfaces. I boil chicken tenders for our dogs and I don't want any oil with them, and that's when I've had the most problem with boil-overs. I'd get busy doing something else and look the other way and oops!
With the wooden spoon, it's so interesting to watch. The water stays clear, there is not the turbulence and big bubbles at the surface. The chicken cooks in half the time. I just have the cheap wooden spoon with the dowel handle, too, nothing with a wide handle. DH says he can see that the steam is aero-dynamically redirected to the pot instead of going up. Um, okay. I guess that is probably true because another plus is that the room doesn't get as humid. Whatever the reason, I sure like this handy hint.
lampooner
South Carolina
Posted: 07/02/12 04:36am Link  |  Print  |  Notify Moderator
Not sure which came first, the wooden spoon or a green twig.
I learned as a youngster, when camping 50+ years ago, to put a fresh green twig from a tree across the coffee pot on the fire to prevent boil overs.
Lampooner
Remember you are only young once,
but you can be immature forever!
GailS
Vero Beach FL
Posted: 07/02/12 05:36am Link  |  Print  |  Notify Moderator
I haven't heard that one either. Thanks for posting.
CA POPPY
Posted: 07/02/12 07:55am Link  |  Print  |  Notify Moderator
See, I KNEW that was an old timey trick. Now DH remembers that his mom used to lay the wooden spoon across the pot while beans cooked, but he assumed she was just resting it there. His Mom was born in 1906. Bet she learned that from her granny. [emoticon]
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
