RV.Net Open Roads Forum: Towing: Grabby Brakes in Stop andf go traffic
Search only in Towing
Open Roads Forum  >  Towing
 > Grabby Brakes in Stop andf go traffic
Chase_Fair
Anchorage, Alaska
Posted: 07/09/12 08:47am Link  |  Print  |  Notify Moderator
In need of some advice-
I just purchased a new toy hauler and have some issues with the brake controller I have. Odyssey 52810 Proportional brake controller and handles up to 8 brakes systems. I seem to have troubles with the brakes in Stop and go city traffic, they get really grabby and I have to turn then off so I don't jerk my mollers out when I got to stop. on the highway they work great and I am able to brake smoothly. How do I find that happy median of both Highway and city driving?
Chase Fair
2002 Ford F-150 7700 Payload Package B w/ Husky 16K hitch
2013 Work and Play 27UL 28ft
Anchorage, Alaska
Dave&Monica
Ontario
Posted: 07/09/12 09:07am Link  |  Print  |  Notify Moderator
That doesn't sound right. The advantage of a proportional BC is that sends current to the camper brakes proportional to the braking force applied by the truck using a mercury switch (or similar) to measure braking force.
Suggest you try going through the initial set-up again shown in the manual. Hopefully you have the BC mounted reasonably level.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
BarneyS
S.E. Lower Michigan
Posted: 07/09/12 09:10am Link  |  Print  |  Notify Moderator
In looking at the specs and the installation instructions for that controller, it looks like it has four load range settings that function very similar to the Prodigy's "boost" settings. I have a Prodigy and have found that on the highway I use boost "3" but when in town I need to reduce that to boost "1" or I will get the jerky feeling that you are experiencing.
Changing the boost setting is easily accomplished by just pushing a button. I think that is what you need to do also. Just push the Load Range Setting button to a lower setting when you need to drive slowly, like in a campground or in town. You DO need to remember to put it back to a higher setting when going back to high speed though.
I believe this will solve your problem assuming your controller is set up properly to begin with.
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Visit our website here
RedG
Fort Worth Texas
Posted: 07/09/12 10:17am Link  |  Print  |  Notify Moderator
I had the same problems and solution as BarneyS.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
dodge guy
Bartlett IL
Posted: 07/09/12 12:08pm Link  |  Print  |  Notify Moderator
Yep, lower the boost in stop and go traffic!
Wife Kim ">
Son Brandon 13yrs">
Daughter Marissa 12yrs">
Dog Bailey ">
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam, Prodigy brake controller
A bad day of camping is
better than a good day at work!">
Terryallan
Foothills NC
Posted: 07/09/12 12:09pm Link  |  Print  |  Notify Moderator
Our brakes were really grabby in stop, and go traffic. It was a Voyager BC. A new Prodigy fixed it. Once they were set. It is as if the TT brakes, and the TV brakes are one.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
GaryWT
MA
Posted: 07/09/12 06:03pm Link  |  Print  |  Notify Moderator
I am constantly changing mine, in stop and go I turn it down to about 1.5 but in normal travel I put it at 2 or 2.5, seems to work. I know they are all different though.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
N3YMY
Brunswick, MD
Posted: 07/09/12 05:25pm Link  |  Print  |  Notify Moderator
Sounds like everyone has their gain turned up too high.
With proper gain adjustment, our P2 does well in both stop and go and highway traffic on boost 2.
(our tv and camper have similar weights; CGVW is about 19800)
Chase_Fair
Anchorage, Alaska
Posted: 07/09/12 04:49pm Link  |  Print  |  Notify Moderator
Thank you all for taking the time answer my questions. I wll go out tonight and find a vacant road and walk through the instructions again.
Exocet
Central NY, USA
Posted: 07/10/12 07:28pm Link  |  Print  |  Notify Moderator
With our old TT, I set my Prodigy up, and never touched it again. With the new TT, that's not the case. For highway speeds, I use a higher setting. But, at lower speeds, this setting ends up locking up the brakes just prior to coming to a stop. So, when I'm in a stop and go situation, I turn it down a bit. I've tried different boost settings, but haven't been able to find one combination that works well.
2008 Nissan Titan SE, Crew Cab, 4x4
Long Bed, Big Tow, Roadmaster Active Suspension
2009 Spree 318BHS
Reese Strait-Line 1200#
Tekonsha Prodigy
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
