RV.Net Open Roads Forum: Class A Motorhomes: 1999 Bounder Converter
 > 1999 Bounder Converter
1L243
Canyonville Oregon
Posted: 07/10/12 08:26am Link  |  Print  |  Notify Moderator
What would be the typical original equipment converter in a 1999 Bounder? Would it be a multi stage battery charger?
2016 Keystone Premier 19fbpr. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
Rampage motorcycle lift to load bike in back of truck.
Sold
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
trickyvic3
Raymond NH.
Posted: 07/10/12 08:41am Link  |  Print  |  Notify Moderator
Can you give us the name and model# off the converter? This will help us determine what you have.
1L243
Canyonville Oregon
Posted: 07/10/12 08:55am Link  |  Print  |  Notify Moderator
Actually I am trying to get some information for my friends Motorhome and don't have that information and he does not know where to find it.
RLS7201
Posted: 07/10/12 09:07am Link  |  Print  |  Notify Moderator
Fleetwood was still installing single stage converters in Bounders in 1999. It will probably be located in the first compartment behind the stairs or in the space under the refrigerator.
Richard
michelb
Ottawa, ON, Canada
Posted: 07/10/12 11:07am Link  |  Print  |  Notify Moderator
Probably depends if it's a Bounder or Bounder Diesel. I believe the Diesels came with a Freedom 20 inverter which I think has a 3 stage charger.
1L243
Canyonville Oregon
Posted: 07/10/12 11:20am Link  |  Print  |  Notify Moderator
It's gas Pretty sure it's V 10 Ford . Wide Body 30 or 31 feet...
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
