RV.Net Open Roads Forum: Towing: 5th Wheel Porpusing
Search only in Towing
Open Roads Forum  >  Towing
 > 5th Wheel Porpusing
jch88_1
Irving, TX
Posted: 07/12/12 06:34am Link  |  Print  |  Notify Moderator
I have 09 Chevy 2500 HD ext cab with 6.0 litre, 3.73 rear end, std bed. I pull a 30ft Rockwood Signature Ultra-lite rated at 78oo lbs with rear kitchen.
My problem is porpusing when traviling at reg speeds and the seams in the roads cause the trailer to porpuse(bounce) up and down starting in the rear, it acts similar to a seesaw.
Is it poosible the balance of the trailer is off, too light wt of the truck?
Has anyone experienced this before and was there a fix action that resolved the issue.
JCH88_1.
Dick_B
Palos Heights, IL USA
Posted: 07/12/12 06:47am Link  |  Print  |  Notify Moderator
Does this happen on asphalt roads or just on concrete roads with the joints evenly spread?
We have the same problem with our TT on some concrete roads. You might try varying the speed in case there is a sympathetic vibration in the RV that just matches the joint spacing at certain speeds.
It's a radical idea but I wish the concrete road builders would stagger the joints.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
netaq
Atlanta, GA
Posted: 07/12/12 07:34am Link  |  Print  |  Notify Moderator
Do you run stock shocks? If your weights are all proper, <$350 for a set of decent shocks (such as bilstein 5100) would definitely help.
2016 Sierra 371REBH
2016 Ram 3500 Big Horn 6.7/Aisin
donn0128
Pronounced Ore-gun
Posted: 07/12/12 06:54am Link  |  Print  |  Notify Moderator
Load up like your going camping Nd go to the scales. Get some good weights. Then dr the trailer and weight the truck itself. Guesses are just that. Accurate weights will tell the story.
Don,Lorri,and our new pup Charlie
The Other Dallas
Over 1,200 volunteer hours
RCMAN46
NorthWest
Posted: 07/12/12 07:47am Link  |  Print  |  Notify Moderator
X2 getting real world towing weights is easy, cheap and may give the answer you want. I suspect your pin weight is too low. You need following weights with trailer in camping trim. Truck front axle, then both axles on truck, then both axles on truck and front axle of trailer, then all 4 axles. Disconnect the trailer and front axle of truck then both axles of the truck. With these 6 weights you can determine all that is needed to make sure you are good to go.
How level is your trailer in camping trim?
TomG2
Central Illinois
Posted: 07/12/12 07:58am Link  |  Print  |  Notify Moderator
I had a similar setup and the closer I got the trailer to level, the better it towed. There are some expensive hitch options that promise to help also.
* This post was edited 07/12/12 08:22am by TomG2 *
APT
SE Michigan
Posted: 07/12/12 10:17am Link  |  Print  |  Notify Moderator
May need better WD hitch adjustment. Start by the forum sticky.
2012 VW Passat TDI
2017 Subaru Outback 3.6R
BarneyS
S.E. Lower Michigan
Posted: 07/12/12 11:27am Link  |  Print  |  Notify Moderator
According to his thread title, he has a 5th wheel trailer, no WD involved.
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Visit our website here
APT
SE Michigan
Posted: 07/12/12 01:51pm Link  |  Print  |  Notify Moderator
Doh. Sell, road speed you can vary. If your truck is anything like my Suburban, the OEM shocks are underdamped brand new. Seems like a good place to start replacing.
Wes Tausend
Bismarck, ND
Posted: 07/13/12 02:51pm Link  |  Print  |  Notify Moderator
My buddy had that problem. He used a small 20 foot 5th wheel and 1/2 ton combo goose-neck set up of which the gooseneck is a bit more prone to springiness, I think.
I thought it was mostly his hitch truck mount. The main hitch frame mount was basically a custom side-to-side 3/8's flat plate under the box, but above the frame rails. I thought it was flexing.
He cured it by a new, bigger 5vr and 3/4 ton truck, so we'll never know for sure. As others have mentioned, new high quality shocks should help, especially on the up/down motion.
The point is... where is is the fore-aft flex coming from, if it too exists? As an example, if a string were taped from the cab to the 5vr front, it would tear loose and/or gain slack during the harmonic motion. Shocks may damp it, but why does this supposedly rigid connection give to start with?
Wes
Days spent camping are not subtracted from one's total.
- 2000 Excursion V-10 - 2000 F-250 CC 7.3L V-8
- 2004 Cougar Keystone M-294 RLS, 6140# tare
- Hensley Arrow - Champion 4000w/3500w gen
- Linda, Wes and Quincy the Standard Brown Poodle
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
