RV.Net Open Roads Forum: Toy Haulers: Weekend Warrior Quick Charge Question
Search only in Toy Haulers
 > Weekend Warrior Quick Charge Question
allcool
sFL_Glamis_PHX
Posted: 07/24/12 09:17pm Link  |  Print  |  Notify Moderator
Z28ROC wrote:
The controller eliminates the need to plug in, and unplug the the little jumper. Also automatically senses the mode it needs to be in. Basically it eliminates the guesswork, and human error. For instance you forget to unplug the jumper, and overcharge your batteries for an extended period of time.
That's the way I understand it. Someone correct me if I'm wrong?
That is exactly how I understand it also.
End of last dune season I got the little IQ4 smart charger($25now, was $20)...
https://bestconverter.3dcartstores.com/IQ4-Smart-Controller-1224-Volt_p_321.html
and switched it out with the little jumper plug. Don't notice a big difference in my voltage when charging. Although I only get 120v to convertor when the genny is running maybe 1-4 hours a day max. But that charges me up to 12.7v on my 2 12v agm 100ah batteries. I never am able to plug into shore power since I dry camp almost always.
Solar power is in my near future...
jmo
* This post was edited 07/24/12 09:35pm by allcool *
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
1 1976 Brazilian Ho
F350 CC 6.7PS Platinum
River&Sand
San Diego, CA USA!!!
Posted: 07/24/12 09:54pm Link  |  Print  |  Notify Moderator
LowRyter wrote:
but my electrical box has a phone plug type connector already in it.
Most of the WW's came with the Iota DLS series of converters Here If yours is like one of these then the IQ4 is what connects in the phone type plug and toss the jumper.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex ">
01 HighJumper SandSprite 3 Dune Buggy ">
LowRyter
OKC
Posted: 07/26/12 06:46pm Link  |  Print  |  Notify Moderator
thanks
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
carringb
Corvallis, OR
Posted: 07/26/12 08:59pm Link  |  Print  |  Notify Moderator
FYI - 30 amps continuous will damage a single battery. Even in as short as 30 minutes it can start boiling.
If you have dual batteries, 15-amps is OK for much longer time periods, as long as it is truckled down once the batteries are charge. Also, it it is high-amp mode at night, good change a lot of juice is going to lights and appliances.
Bryan
2000 Ford E350 DRW Wagon, V10 - 400,000+ miles!
2014 CreekSide 31KQBS (QuadSlide bunkhouse)
2015 Ford Fiesta 0.999L EcoBoost
chiggly626
Home
Posted: 07/27/12 07:08pm Link  |  Print  |  Notify Moderator
Quick answer is to use the jumper when dry camping and on generator power, unplug jumper when plugged into shore power.
64thunderbolt
Az
Posted: 07/28/12 01:37am Link  |  Print  |  Notify Moderator
Best answer yet
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
LowRyter
OKC
Posted: 07/28/12 01:31pm Link  |  Print  |  Notify Moderator
for sure, but the question is to do it for long term storage?
64thunderbolt
Az
Posted: 08/01/12 12:30am Link  |  Print  |  Notify Moderator
Why would you want to use anything for long term storage? I flip the cutoff switch and leave mine for several months without any problems.
nayther
Burbank, CA
Posted: 08/01/12 09:50am Link  |  Print  |  Notify Moderator
For long term storage either disconnect the batteries via the switch or use the smart charger. DO NOT leave the trailer plugged in without doing either of the above or you will boil the batteries.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
N-Trouble
NorCal
Posted: 08/01/12 12:24pm Link  |  Print  |  Notify Moderator
But ultimately you will forget its plugged in and end up frying your batteries when you reconnect to shore power. With the IQ4 plugged in its now dummy proof.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
