RV.Net Open Roads Forum: Built A New Entry Door For My Truck Camper!
 > Built A New Entry Door For My Truck Camper!
CaveRun
Kentucky
Posted: 07/25/12 06:42am Link  |  Print  |  Notify Moderator
I started to rebuild the entry door on my truck camper because it had some rot in the bottom, and it was sagging so much that it was dragging against the door frame.
When I took it apart, I noticed right off that the factory didn't put enough wood for the frame in the door... I know they wanted to cut down on weight.
Here's some pictures of my old door.
So I built a new door and I built it A LOT stronger!!!.. I used 2x6's for the outside frame, and 3 short pieces of 2x4's and a couple 2x2's... I also put L-brackets in the corners.
To skin the new door, I bought a 4x8 sheet of Sequentia white FRP wall panel from Lowe's for $37.40... It will not mold, mildew or rot and its very easy to cut and work with!..(just make sure you wear a mask when cutting it)... I used some contact cement from Lowe's to glue it to the wood, and it sets up very quick!
The door is very well built, and its much heavier than the old door but will last a long time... In the old door they had a window at the bottom, and when I built a new one I didn't want to add it back in.
I checked Online to see how much new doors costs, and couldn't believe they were $1,000 dollars... I have a little over $60 dollars in this door, and I'm very pleased with the way it turned out!
If you have any questions just ask!
Here's some pictures of the new door I built.
* This post was edited 07/25/12 07:10am by CaveRun *
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
ryanallie1
Fall River Mills, Calif
Posted: 07/25/12 06:54am Link  |  Print  |  Notify Moderator
Hi All.
You just have to admire a real nice professional job when its done. Now at least you know you have one very solid built door,
Good Job, bet you feel great, not to mention, not having to buy anohter over-priced door that wouldn't hold up any better than your last one did.
Good Luck. Happy Travesl. Dan & Jill
1998-34 ft Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
LAdams
Northern Illinois
Posted: 07/25/12 07:04am Link  |  Print  |  Notify Moderator
Excellent job Cave Run!! [emoticon] [emoticon] A quality build and great craftsmanship... That door will probably outlast the entire camper [emoticon]
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
AhNuts
East Coast
Posted: 07/25/12 07:18am Link  |  Print  |  Notify Moderator
Top notch work, well done.
John
jiveturkey692000
NE PA
Posted: 07/25/12 09:15am Link  |  Print  |  Notify Moderator
Good job!
Dan">
96 Fleetwood Mallard, 30'
05 Ford F250 Super Duty 4X4 6.0 Powerstroke, CC, Lariat 8ft Bed "Redneck Cadillac"
82 Dodge Ram W350 4X4 Clubcab. 216,000 miles
ScottG
Bothell Wa.
Posted: 07/25/12 09:34am Link  |  Print  |  Notify Moderator
Super nice work.
spacedoutbob
SF Bay Area
Posted: 07/25/12 10:10am Link  |  Print  |  Notify Moderator
Great Job! I need to work on my door also, You have just inspired me to do the same. Thanks for posting.
Bob in Calif.
Good Sam Club Life Member
dakonthemountain
Crestline, California
Posted: 07/25/12 02:33pm Link  |  Print  |  Notify Moderator
WOW! 2 x 6" framed door! Stronger than one in a stick house! Kudos on a GREAT job!
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
dboliek1112
Perryville, AR & Raleigh, NC
Posted: 07/25/12 04:06pm Link  |  Print  |  Notify Moderator
Congratulations on a really fine job.
"The only thing more expensive than education is ignorance." Benjamin Franklin
Dave and Missy Boliek
Roxeanne, Bell and MaggieMoo
2000 Winnebago Chieftain
2007 Saturn Aura
SoCalDesertRider
Arizona desert
Posted: 07/25/12 05:11pm Link  |  Print  |  Notify Moderator
The new door looks great. Very nice craftsmanship there. [emoticon]
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
