RV.Net Open Roads Forum: Built A New Entry Door For My Truck Camper!
 > Built A New Entry Door For My Truck Camper!
Wills6.4 Hemi
meadows
Posted: 07/25/12 05:20pm Link  |  Print  |  Notify Moderator
VERY NICE!!![emoticon]
hershey
Albuquerque,(fulltime) NM, USA
Posted: 07/25/12 08:21pm Link  |  Print  |  Notify Moderator
Take three steps back and admire, then give yourself a hearty pat on the back. Great job.
$1000.00????? And for a lesser crafted door.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
5akman
chico ca
Posted: 10/16/12 12:26pm Link  |  Print  |  Notify Moderator
I need a new cabin door on my 40' fiberglass gillnet boat in Alaska. Even though I'm a retired woodshop teacher, I'd never even thought of building one myself. Thanks for the inspiration!
2001 25' Keystone Sprinter 5th wheel, 2001 Dmax, CC, LB, 2wd, 285/75/16, with new injectors/head gaskets/CP3/water pump at 146,000. Rebuilt Mike L tranny and Trent Nell/EPR tow tune.
Sweet Tater
Mississippi
Posted: 10/15/12 08:31pm Link  |  Print  |  Notify Moderator
CaveRun wrote:
I started to rebuild the entry door on my truck camper because it had some rot in the bottom, and it was sagging so much that it was dragging against the door frame.
When I took it apart, I noticed right off that the factory didn't put enough wood for the frame in the door... I know they wanted to cut down on weight.
So I built a new door and I built it A LOT stronger!!!.. I used 2x6's for the outside frame, and 3 short pieces of 2x4's and a couple 2x2's... I also put L-brackets in the corners.
To skin the new door, I bought a 4x8 sheet of Sequentia white FRP wall panel from Lowe's for $37.40... It will not mold, mildew or rot and its very easy to cut and work with!..(just make sure you wear a mask when cutting it)... I used some contact cement from Lowe's to glue it to the wood, and it sets up very quick!
The door is very well built, and its much heavier than the old door but will last a long time... In the old door they had a window at the bottom, and when I built a new one I didn't want to add it back in.
I checked Online to see how much new doors costs, and couldn't believe they were $1,000 dollars... I have a little over $60 dollars in this door, and I'm very pleased with the way it turned out!
Very nice job
Doc Eagle
South Carolina
Posted: 07/26/12 05:17pm Link  |  Print  |  Notify Moderator
Really a $1000 for a light weight door??? Geez, what is theirs made of gold? Impressive job, should last for years... Congrats!
1993 Fleetwood Flair 22D "Cat One"
USN(RET)
Fire Captain(Career)
Fire LT(Volunteer)
CaveRun
Kentucky
Posted: 07/27/12 05:17am Link  |  Print  |  Notify Moderator
Thanks everyone for the kind words!!!
I got some info' from this Forum before I built the door, and before I registered to be a member... This is such a great place with A LOT of great info!
Thanks!
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
the_wanderer
texas
Posted: 11/03/12 06:27am Link  |  Print  |  Notify Moderator
Hey, CaveRun....did you use pocket screws for fastening the framework?
AllegroD
Outdare
Posted: 11/03/12 11:12am Link  |  Print  |  Notify Moderator
Very nice work.
