RV.Net Open Roads Forum: Technology Corner: Portable Router
 > Portable Router
robatthelake
Vancouver Island
Posted: 07/27/12 11:30am Link  |  Print  |  Notify Moderator
We have been totally spoiled by the Internet Provider in that They have always provided a Wireless Router along with the Internet Service.
When travelling these devices are not tranportable so not really of any use in the RV.
This Winter We will once again hit the Road and rather than depend on Free WIFI which can be hit or miss We are going to use an Internet USB "Stick".
We would like to be able to use more than one Laptop/Tablet at a time so are wondering what Other Folk are using for an on board Router?
Can You suggest a decent Brand and model that works with a USB Stick?
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
MegaJohn
NW Geogia
Posted: 07/27/12 12:02pm Link  |  Print  |  Notify Moderator
We use a CradlePoint CTR35 (I think) router (CradlePoint CTR35). It's very compact, AC powered, accepts our USB 3G device, and broadcasts WIFI. We keep the router in our camper's bedroom and it broadcasts around our whole site.
When I set it up, I configured the router to request a password from all devices connecting to it. After we've connected the device, it functions just like our home router.
Happy Camping!
John.
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
ronfisherman
SE Michigan
Posted: 07/27/12 12:57pm Link  |  Print  |  Notify Moderator
I have the same Cradlepoint router. Works very well with our air card. Last fall we got a smartphone that supports hotspot. This has been a better and cheaper setup than our air card. Still use the Cradlepoint to retransmit the signal at times. You may also want to look at a Verizon MIFI. You can have up to 5 connections on it.
2012 Chevy Captiva Toad
Super C Group Forum
AllegroD
Outdare
Posted: 07/27/12 01:00pm Link  |  Print  |  Notify Moderator
WIFI Ranger Go has multiple capabilities.
hawkman541
Livingston, Texas
Posted: 07/27/12 01:38pm Link  |  Print  |  Notify Moderator
We use a similar setup as "MegaJohn", but a different brand. We use a pay as you go USB Stick from Verizon that plugs right into the router, and we have a external extended range Wi-Fi antenna with built in Wi-Fi adapter that connects to the router via USB. I mount the Antenna on a short stick of 3/4"pvc and place that into a 1" pvc that is clamped to the ladder, and run the cable in via the slide. I get a boost to 100% on 75% of the signals I see. I can reach 3 to 5 miles with that antenna. For security, I use Avast Security Suite that comes with it's own secure browser when needed for banking and the such. Out of 12 months, I've used free wifi 10 months. Hope this helps, good luck.
2002 Ford F-450 Crew Cab
2013 Heartland Landmark San Antonio
Frank-10lb. Chihuahua
1775
NY
Posted: 07/27/12 03:40pm Link  |  Print  |  Notify Moderator
You can purchase a hotspot instead of the USB stick- same function, but the hotspot allows you to connect up to five devices by wifi to the Hotspot. Most providers that sell the usb stick also sell the hotspot box. There are also some Android phones and Iphones that are enabled to do the same thing using the phones data service.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
1492
Washington, DC
Posted: 07/27/12 03:53pm Link  |  Print  |  Notify Moderator
I would also think a mobile hotspot device would be easier to setup and less possible compatibility issues than a USB stick.
 > Portable Router
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
