RV.Net Open Roads Forum: Tow Vehicles: Will my 2010 F150 tow it?
Search only in Tow Vehicles
 > Will my 2010 F150 tow it?
rlh6805
Michigan
Posted: 07/30/12 11:12am Link  |  Print  |  Notify Moderator
Hello all,
My wife and I recently bought a second home and have found ourselves not using our camper much at all over the past two years. I sold my Excursion tow vehicle and have now sold the camper too. The issue is that now I find myself having to tow the camper about 200 miles to the new owner using my 2010 F150. Here are the stats. Camper = 7,400lbs dry, 9,500lbs GVWR. F150 = 2010 with Max tow package, GVWR = 7,675lbs. The F150 is rated to tow 10k lbs+ so I think I'm ok but I'm old school where I think you need a 3/4 ton to tow anything. Any advise?
Rob and Cindy in Michigan
2004 Prowler Regal
2001 Ford Excursion V10 4x4
Tasha, Deanna (RIP), and Abby (our dogs)
APT
SE Michigan
Posted: 07/31/12 06:25am Link  |  Print  |  Notify Moderator
I'd do it once, but it does not seem worth setting up the WDH for one tow to new owner. Do you have a brake controller still too?
2012 VW Passat TDI
2017 Subaru Outback 3.6R
Magblue10
Valparaiso, IN
Posted: 07/31/12 06:46am Link  |  Print  |  Notify Moderator
IMO you could do this regularly but others may disagree but one time will not be an issue at all
rlh6805
Michigan
Posted: 07/31/12 08:08am Link  |  Print  |  Notify Moderator
Hi,
I really was hoping to not have to mess with the WD setup and since I have the Max Tow package on the F150 is has a built in brake controller. I'm kinda curious to see how it works.
rlh6805
Michigan
Posted: 07/31/12 08:10am Link  |  Print  |  Notify Moderator
Yea, it is only going to be a one time trip. It seems that the newer 1/2 ton trucks are rated to tow what the older 3/4 ton's were and the new 3/4 tons are like the old 1 ton's.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
