RV.Net Open Roads Forum: Fifth-Wheels: Looking at Used HR Alumascape
 > Looking at Used HR Alumascape
Charlie D.
E. Texas-Orange
Posted: 08/02/12 08:55am Link  |  Print  |  Notify Moderator
Your issue with HR is known to many of the forum members and , IMO, you were not treated fairly.
All manufacturers has their share of lemons. Some more than others. My neighbor works refinery outages and his new Big Horn burnt 1/2 of it's 110v wiring, AC and other items. He had to live in that rig because he is a traveler. It took 11 months to get the electrical straight. Cost him a lot of money to rent housing while it was back and forth to the dealer and finally to the factory. I was in a campground 2 months ago and a Landmark has a gap between the front cap and side that you could stick a finger through. Don't know the results of what happened after that.
My entry level 2007 Savoy LX, except for tires and spring bushings, gave me 40,000 trouble free miles. Not one warranty issue
Enjoying Your Freedom?
Thank A Veteran
Native Texan
towpro
Compass PA
Posted: 08/02/12 10:16am Link  |  Print  |  Notify Moderator
As I look at the recalls on HR, it seems the 2001-2005 have frame recalls to add gussets and new cross members. (I had a 2000 Terry recalled for the same issue)
I see recalls for Chrome Rims where the rim comes apart, but this one has cast wheels (might have been replaced under warranty).
I also see a little info about 2007 or later having some Lippert frame (poor welding) problems. But not much on 2006. Is 2006 the year they were out of business and they might not have produced many 5er that year? I need to check the build date on this one.
Next time I go to see it I will wear cloths so I can craw underneath it.
2016 Arctic Fox 990
2015 Ram 3500 Cummins DRW 4wd Aisin 8' bed.
All I added was 1-5/16" sway bar.
kakampers
Fulltimer
Posted: 08/02/12 11:25am Link  |  Print  |  Notify Moderator
The frame that gave us the issue was Venture...Monaco swore it had a Lippert frame, but it did not...had to send them pics to prove it! That's how we found out it was basically built on the wrong frame....this was in spring of '07...unit was built in '06.
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
kakampers
Fulltimer
Posted: 08/02/12 11:33am Link  |  Print  |  Notify Moderator
Charlie D....so true, Monaco was terrible to deal with. If we'd used our heads...they would have bought it back. But that's water under the bridge...happy with our Bighorn, and looking to upgrade next year.
As for all manufacturers making bad units...true again, and Heartland is no exception...however, they do not build their units on old, recalled frames.
kakampers
Fulltimer
Posted: 08/02/12 11:37am Link  |  Print  |  Notify Moderator
Double post...darn cellphones....LOL
towpro
Compass PA
Posted: 08/02/12 12:18pm Link  |  Print  |  Notify Moderator
Kakampers, is there an easy way to ID if the one I am going to see is a Lippert or Venture frame? It is a 31SKT
kakampers
Fulltimer
Posted: 08/02/12 12:27pm Link  |  Print  |  Notify Moderator
Ours was a 33skt...it had venture stamped right on the pinbox....if it's Lippert it should also be on the pinbox.
towpro
Compass PA
Posted: 08/02/12 12:59pm Link  |  Print  |  Notify Moderator
Thanks KaKampers. I see we are both in PA, but you had a different model (and 1 year newer) so we know it's not your old rig [emoticon]. I am east of Lancaster.
GPax
PA
Posted: 08/02/12 03:29pm Link  |  Print  |  Notify Moderator
We ordered a 2004 AlumaScape and heve pulled it to Colorado, Utah, South Dakoda or New Mexico from SE PA every year since we have had it. Aside from one tire blowout (Good Year) one broken spring ply in Ohio (limped home) and a problem with the living room slide last year, (slide always came in only would not fully extend) the unit has been trouble free. That's a lot of miles in 8 years over some pretty poor interstates. I'd be curious who the dealer is, if it's the one we have I wouldn't hesitate a minute to buy it. In the end it doesn't matter the brand......It's how well it's been taken care of and the DEALER your buying it from.
Pax
kakampers
Fulltimer
Posted: 08/02/12 05:05pm Link  |  Print  |  Notify Moderator
Be glad..Be VERY glad...LOL!
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
