RV.Net Open Roads Forum: Class A Motorhomes: '93-94 Southwind - No Lpg?
 > '93-94 Southwind - No Lpg?
wildbill001
TX
Posted: 08/08/12 08:17pm Link  |  Print  |  Notify Moderator
Picked up a '94 Southwind last week. In going through everything once it got home, it appears that the LPG is not flowing. My wife tells me she tested the stove (I was out of town while she was shopping) but now, nothing.
The gauge on the tank says 1/4 full but how accurate is that? I've looked through all the books to make sure there is not some switch or something I need to flip (and yes, the pilot light valve is open). I have left the burners "on" for about 20min but nothing seems to be moving and there is no smell.
So before I get the tank filled, thought I'd check with the experts to see if I am overlooking something?
Bill W
gbopp
The Keystone State
Posted: 08/08/12 08:20pm Link  |  Print  |  Notify Moderator
Is the valve on the tank open?
past-MIdirector
Michigan
Posted: 08/08/12 08:50pm Link  |  Print  |  Notify Moderator
Look along the floor edge for a LP detector and make surn it's on. Most Fleetwoods have the LP Detector along the bottom of the kitchen cabinets. Most will beep a few times when turned on.
enblethen
Moses Lake, WA
Posted: 08/08/12 09:01pm Link  |  Print  |  Notify Moderator
LP detector operates a solenoid next to the LP tank.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
2003 Chev Ice Road Tracker
gsf35099
Granite Shoals, TX
Posted: 08/08/12 09:06pm Link  |  Print  |  Notify Moderator
That's right, now i remember. I was asking my wife what was causing our Southwind to not flow gas and I had shut that off.. [emoticon]
OP, as they said, look for the LP monitor and make sure its on.
2005 Damon Astoria 38.6' DP
300 Cummins ISB, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
rockhillmanor
On the Road
Posted: 08/08/12 09:15pm Link  |  Print  |  Notify Moderator
So before I get the tank filled, thought I'd check with the experts to see if I am overlooking something?Bill W
First of all, you DID open the valve outside, right?
AND
Aren't you'all in the middle of a heat wave down there? [emoticon]
Accurate 1/4 tank readings are iffy at best. And propane expands in the heat which affects readings. I'm thinking you are out, as long as you DID turn the valve on that is!!
http://www.propane101.com/propanevolumecorrection.htm
The liquid propane volume in any LP Gas container is directly related to its temperature. In fact, the volume of any liquid in any container is directly related to its temperature. Propane volume rises as temperature rises and falls as temperature falls. Being temperature dependent, propane becomes more dense as temperature falls and expands as temperature increases. This is extremely important to remember when understanding propane temperature and volume and the relationship between the two....."
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
MrWizard
Traveling
Posted: 08/08/12 09:50pm Link  |  Print  |  Notify Moderator
battery disconnect ?
state of the batteries ?
low voltage can cause the LP detector to shut off the LP safety valve
Connected thru Verizon with HotSpot WiFi using a Samsung S4 and/or Novatel 2200 MiFi
wildbill001
TX
Posted: 08/09/12 05:40am Link  |  Print  |  Notify Moderator
Yup tank valve is open. Totally forgot about the propane alarm. Will check that and see where we are afterwards.
Thanks!
camperkids1025
Bel Air, MD.
Posted: 08/09/12 06:09am Link  |  Print  |  Notify Moderator
Yup Gotta love it!! You can always learn something new here on the forum. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
Steelsmith
Nampa, Idaho
Posted: 08/09/12 08:19pm Link  |  Print  |  Notify Moderator
One other thing you might have is a slugged valve? That happens when the propane valve is turned on too fast. It's a safety feature to prevent rapid expelling of the propane should the hose break or regulator break.
Just shut off the tank evacuate the line by turning on the stove for a minute, then shut off the stove. Open the valve on the tank again just do it slowly, as in bleed the propane into the system.
There may be other issues, but this is one you don't want to overlook as it's very basic.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
