RV.Net Open Roads Forum: How much water to use when flushing
 > How much water to use when flushing
Camper Ken
Oregon
Posted: 09/10/12 12:24pm Link  |  Print  |  Notify Moderator
Although I've been RV'ing for several years I have a question. When flushing an RV toilet how much water should one use? If it's liquid waste, is any additional water needed? Obviously for solid waste some addition water is required for the flush but how much more to insure proper breakdown in the holding tank?
For weeklong dry camping trips I'd like to maximize the use of my 40 gallon holding tank, so all advice and opinions are appreciated.
Ken
2016 Itasca Navion 24J
swebber
Bluemont
Posted: 09/10/12 12:36pm Link  |  Print  |  Notify Moderator
Ive never dry camped but understand your concern on water management.
When I flush, for liquid, just the three to four inches of water in the bowl go down with maybe a second or two of extra to rinse then I fill the bowl back to the three inch level. For solids, I get all the paper down and make sure any remnants are down the hatch.
You could carry a gallon or two in jugs to use for filling your toilet bowl up. I carry a gallon jug for "on the road" flushes.
Steve Webber
2013 RAM 3500 Dually, 6.7 Cummins and all the bells and whistles
2009 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
M GO BLUE
Southgate, MI
Best way to think is before you dump the black tank is to make sure it is at least 2/3 full (full is even better which will help any solids to slide right out)
...and yes you should always add water when flushing...we count to three after we flush
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Camper Ken
Oregon
Posted: 09/10/12 12:40pm Link  |  Print  |  Notify Moderator
When I said "For weeklong dry camping trips I'd like to maximize the use of my 40 gallon holding tank... " I meant the black tank. I have plenty of capacity in my freshwater tank so carrying extra water for on the road flushes is not a concern.
Thanks for your advice though.
Ken
Sandia Man
Rio Rancho, NM
Posted: 09/10/12 12:42pm Link  |  Print  |  Notify Moderator
We always start off with a few gallons (after dumping/rinsing) in the tank and always add a bit of water (more with solids) with each use. Our 40 gallon black tank will normally last a week before needing to be dumped.
BCSnob
Middletown, MD
Posted: 09/10/12 12:46pm Link  |  Print  |  Notify Moderator
I fill up the bowel enough to flush as opposed to running water into the open hole.
Lay off the beer and coffee, it'll reduce how much liquid you're putting in the tank. [emoticon]
SWD
Land of Living Skies
Posted: 09/10/12 12:55pm Link  |  Print  |  Notify Moderator
For liquids I dont use any flush water but for solids I fill the bowl to about the top and let it go.
gijoecam
Midwest
Posted: 09/10/12 01:15pm Link  |  Print  |  Notify Moderator
We still haven't found the balance between too much and not enough water with the flush. (We only have a 30 gallong black tank, for the record)
In a week of camping with full hookups, we'll fill it in the first two days, then go five or six days without filling it. When we camped without hookups last summer, we went about three days with heavy use. However, when I pull the flush handle, the majority of what comes out looks to be liquid, so I think we're still over-using the water. If we've got hookups, it's not a big deal, but I can see it becoming an issue next month when we driveway camp at a friend's place for a few days.
RCMAN46
NorthWest
Posted: 09/10/12 02:08pm Link  |  Print  |  Notify Moderator
You did not indicate how large your fresh water tank was. In my case my gray and black tanks have much more capacity than my fresh water. Thus if I do not add water to the fresh water then it should not be possible to overfill the black tank. I use a full bowl of water before flush every time it is solid waste material. The more water you use the less trouble you will have with the black tank.
rockhillmanor
On the Road
Posted: 09/10/12 02:30pm Link  |  Print  |  Notify Moderator
After using the toilet, fill the bowl with a little less than half of what you would you see sitting in your house toilet.
After you flush all the water you need in the bowl is just enough to ensure the opening is covered with water to seal out any sewer gas from getting past it from the tank.
This ;ast step is where you can conserve water, there is not need to fill it up 'after' you flush and then fill it up again to flush. We are just used to seeing that in our house toilets.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
