RV.Net Open Roads Forum: Alarms going off when water pump runs, even with shore power
 > Alarms going off when water pump runs, even with shore power
mkirsch
Rochester, NY
Posted: 09/17/12 10:09am Link  |  Print  |  Notify Moderator
The CO alarm likes to go off while I'm taking a shower. I was told it was because of low voltage.
I've been pulling the fuse for the alarms while I'm in the shower so I don't have people busting into the camper to "rescue" me while I'm buck naked.
Last weekend I camped with SHORE POWER for the first time.
Even with the converter's help, the CO alarm started chirping as soon as I turned on the water pump.
Any ideas what's going on?
steve&vonna
Colorado
Posted: 09/17/12 10:34am Link  |  Print  |  Notify Moderator
Is there any chance water vapor from your shower is getting to the alarm?
We have a smoke detector located close to one of the bathrooms in our house, after several years of service the alarm sounds whenever we take a shower.
Running the vent fan in the bathroom eliminates the problem. I'm not sure if CO2 alarms can be sensitive to water vapor, anyway if your not running the bathroom vent fan when showering you might try turning it on and see if it helps.
Steve
Jaxom
Eastpointe, MI
Posted: 09/17/12 10:38am Link  |  Print  |  Notify Moderator
With all the problems you are having with the CO alarm, I would just get a new one. You don't want one that might NOT work on a legitimate event.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
AnEv942
CA
Posted: 09/17/12 11:04am Link  |  Print  |  Notify Moderator
Your CO detector is hard wired for power?
* This post was edited 09/17/12 11:37am by AnEv942 *
Our camper projects page
jimh425
Western MT
Posted: 09/17/12 01:03pm Link  |  Print  |  Notify Moderator
CO alarms only last a limited period of time. I think it is 5 years. I had one that was erratic. I found it easier to replace although there is supposed to be a way to fix them. Cleaning didn't seem to help.
wing464
Any where retirement takes me
Posted: 09/17/12 01:45pm Link  |  Print  |  Notify Moderator
Recently had the alarm issue as you describe.....Mine was a low voltage issue and once I had the batteries checked out and replaced both (only 1 had a problem)the alarms quit sounding off.
mkirsch
Rochester, NY
Posted: 09/17/12 01:47pm Link  |  Print  |  Notify Moderator
Both detectors (propane, and CO/smoke) are hard-wired into one of the converter's 12V circuits.
As soon as I turn on the pump to build pressure, the detector starts chirping.
Both detectors are originals that came with the camper. I should just replace them with 9V battery powered models and be done with it.
AnEv942
CA
Posted: 09/17/12 03:20pm Link  |  Print  |  Notify Moderator
12 years old? think replacing would be good. Actually now that Im think about it our LP detector is original, its hard wired. I was unaware of hardwired CO detectors. Thought, like most smoke detectors, battery powered. Ive only seen hardwired that had battery backup on co/smoke detectors
I would still change out but wonder why pump triggers detector? Or failing detector more sensitive to low/fluctuating power. I know our pump caused our incandesants to flicker.
Good topic for TCU thread
69 Avion
Phoenix, Arizona
Posted: 09/17/12 05:47pm Link  |  Print  |  Notify Moderator
I would get a new hard wired one.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
