RV.Net Open Roads Forum: Truck Campers: Tork wobble stopper
 > Tork wobble stopper
ab257
PA
Posted: 09/21/12 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Installed on the camper. Went on fairly easily. Can't tell how effective it is since the camper is on jacks, but seems fairly sturdy.
NE PA
Ford F350 (2008 XLT CC LWB 6.4L Diesel 4x4 ESOF 3.73 DRW 17"A/S
Upper/Lower Stable Loads, Airbags, Bilsteins)
Host Yukon (1 Slideout, Tent, Solar, 2-way Fridge, AGM)
Jeep Rubicon (Blue Ox tow, Patriot Brake, Tork Hitch, Voyager Cam)
Super_Dave
Harrisville, UT
Posted: 09/21/12 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Did the instructions recommend mounting it low like that? I'm wondering if there is an optimal brace point for stability.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
kerry4951
East Central Pennsylvania
Posted: 09/21/12 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I was always afraid that the stowed wobble stopper would interefere with the clearance between the outer dually fender and the jack.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
ab257
PA
Posted: 09/21/12 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
The instructions show it mounted low, and that would give the most support. When my dually jacks are swung in, the brace is strapped to the back of the jack.
campn4walleye
Central WI
Posted: 09/21/12 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
They do. At least on ours they do, so DH has to remove them every time we break camp. It only takes a few minutes extra. DH changed the bolts and put some sort of grease on them to keep them from seizing on, as they kept doing. He broke a wrench trying to get them off the first time. I guess they are meant to be permanent, but we have square jacks and a dually with VERY little clearance.
They really do increase the stability. No sway even with the big dog moving around.
2011 Adventurer 910FBS truck camper,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD,4x4,LB,CC,auto,3.73 axle,General 17" on/off rd
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
Buffettphan
New Hampshire
Posted: 09/22/12 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Are they worth the money??
2004 Lance 1010
2005 GMC 2500HD
Bilstine Shocks
Hellwigs
Tork lifts
Stables Loads
Thule duel axle trailer
2012 Harley Davidson Electra Glide Limited
2013 Softail Deluxe
2004 Harley Davidson Sportster 883C
campn4walleye
Central WI
Posted: 09/22/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
If you use your TC off the truck most of the time, then we would say yes.
We take our TC off every time so that we can move the boat in and out of the lake. We have a perfectly solid camper thanks to the wobbl-stopprs. We've been in some pretty good winds and didn't even flinch.
INBellbuoy
Indianapolis, IN
Posted: 09/22/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Mine cut the side to side sway but still looking for something to cut the front to back sway.
INBellbuoy, wife of 36 yrs, 19 yr old son, & Scruffy the Goldendoodle, 2007 Dodge 3500 Quad Cab, 2005 Lund 1800 Explorer w/ 90 hp Yamaha & Minn Kota I-Pilot Link , 2006 Host Yukon W/ Tent 80W solar panel
Terrick down Under
Australia
Posted: 09/25/12 05:32am Link  |  Quote  |  Print  |  Notify Moderator
they look good, just put another tow on... I made my own to suit our TC
http://i1176.photobucket.com/albums/x335/TerrickDownunder/Dually%20front%20jack%20braces/P1000320.jpg
Just remember to work out how far your flairs stick out.
ab257
PA
Posted: 09/25/12 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Swung the clamp around to clear the dually flare. May not be quite as sturdy.
But had a tussle unbolting it. The lock nuts that came with the system were not the nylon insert type, but a type that deformed the treads of the bolt making them virtually unremovable. After an hour of trying, finally had to hacksaw the bolt. If you install this, throw away the 3/8" SS nuts and get some regular lock nuts from a hardware store.
