RV.Net Open Roads Forum: ST Tire Failure Analysis (Long - Lots of Pics)
Search only in Towing
Open Roads Forum  >  Towing
 > ST Tire Failure Analysis (Long - Lots of Pics)
JBarca
Radnor, Ohio, USA
Posted: 12/09/12 10:42am Link  |  Print  |  Notify Moderator
This summer I had a tire failure, 3 actually in all by the time I was done. If you are into the details of tire failures, this is one type of tire failure. This is a little long of a post, but there are lots of pics to go with the words and some background.
I'm not a tire expert by any means, just a machinery guy trying to figure out what went wrong with my rig so I did not repeat the same problem and could correct what went wrong. So I took this one as far as I practically could.
I caught the first failure here in my yard doing axle maintenance. When I jacked up the camper to put it on jack stands, my left rear tire would not clear the ground on the normal stand height. H’mm OK what’s up?
I looked at the left rear tire and it looked more round across the face than I remembered. Still did not know what the issue was at this point.
I jacked it up some more and started to take the tires off. I took all 4 tires off and I could see one tire, the left rear looked different. It was more curved across the face of the tire than the rest. Laying it on the ground it showed up more not be square to the sides.
Here is a normal one
After comparing the other 3 to this one rear left I measured the OD of the tire. Yup, it is 1” larger in OD circumference. OK something let loose inside this tire.
I put this bad tire aside, finished up the axle work and put the spare on. I then tried to figure out what was wrong with this tire. Looking on the outside I really did not see anything much that was wrong with it other than about 180 degrees around the outside, the tire progressively was getting larger in OD up to a high spot then starting coming back down. Whatever was wrong with it created an out of round tire.
I demounted the tire and looked inside. Nothing really looked wrong to me inside. I happened to have a fellow RV buddy who is a retired tire engineer who has done tire failure analysis most all of his career. We hooked up and he told me how to section the tire and send it to him. So here is how we did this. [image]
He told me how to cut out the side walls. I was shocked you can cut up a side wall this easy. There is inherent danger in doing this. Heavy gloves and a sharp knife is a must. Once you start cutting it out it sort of unzippers. You start above the tire bead and cut towards the OD, then start and cut around the circumference.
Now the other side. A new blade for the next cut.
Now I had a donut. The hard part is cutting through the steel wire in the tire. Ideally you do this on a vertical band saw with a progressive tooth blade. The rubber wants to bite and grab the blade. I did not have a large enough vertical band saw so I used a Sawzz All. Here one really has to clamp this thing down or the rubber will grab and start shaking the saw violently. You do not want any blade pinch as the rubber bites into the blade. Need to back flex it to keep it pulling apart as you cut. I clamped it to some old saw horses and cut it apart.
I marked with the center of the high spot so he could back into it. I also put that high spot in the middle of the sample.
Now I looked at the cross section. Well nothing real exciting at the 90 degree point from the high point.
So I curled up the sample to fit in a box I could UPS to him. Here it is.
I sent him the tire and then started to investigate if I did something wrong to cause this failure. I always check tire pressure and run max cold side wall pressure at the start of every trip. I even have my own small compressor in the truck if I need it. So under inflation was not the problem.
I also do not tow faster than 60 mph. I do not need to, big truck or not this is a safety limit for me. So I was not overrunning the 65 mph max speed rating creating excess heat.
I use white tires covers when the camper is at home. These tires are 3.5 years old at this point. I can say the first year they were only 50% covered until I have my present tire covers in place. There really was not much tire cracking. No side wall cracks, some very fine in tread cracks and there was a number of stone cuts in the valleys of the treads.
Next was weight. I had not been to the scales in about 1.5 years and I added some upgrades. So I loaded the camper with stuff for a campout and full fresh water as we do haul water to some camps. Went to the scales and weighed each axle with WD engaged. I could not get each wheel position at the scales so when I came home I used my force jack to get each wheel position. Here is the weight chart.
The failed tire location has 12.5% extra tire capacity or 318# from max load. There is some error in this data as my force jacked weighed a little heavy. It did however show me that the 4 tire locations are different. The front axle was pretty equal, the rear axle very different. My fresh tank sits right over the front axle which may have had something to do with the front being more even. At this point, weight did not seem to point to a glaring problem.
Since I could not find anything wrong, yet anyway, I bought a new Maxxis tire for the spare and we headed off on vacation. My tire buddy also was on vacation so he did not yet have my tire done.
On vacation I was 800 miles from home on the NYS Thruway and while gassing up, OMG… This tire right side rear tire does not look good. Dang, it looks like the failed one. So we pulled over in the truck lot and took it off and put the spare on. Yup, it let go too like the 1st one.
I was lucky a 2nd time I caught the failure before it let go. If you are going to have to change a tire on the road, the NYS Thruway makes a good changing spot… OK so now I have no spare…. I’m thinking of where I can get one when I get to my Mom’s house. Well…. No luck finding one close by. We did make it home OK. Another 800 miles.
When we made it home I was already working on changing tires to LT tires. When I jacked up the camper to take off the ST’s, OH boy, another one…. The tread was bulged. This tire would not even roll correct it wobbled so bad it would fall over.
So I dodged a 3rd bullet. I could not see this when it was on the camper, only when I took the weight off. The damage did not yet progress far enough yet or it was not out in the open where I could see it.
Soon my tire engineer buddy was done investigating the 1st tire I sent him. The tire failed for what is called “detachment” or what is nick named sometimes “slipped belts”. It is where the tread separates where the steel belts are in the tire tread from the main tire. Basically the tire unbonded itself inside the tread. Here is his analysis pictures.
He sectioned the tire sample I sent him and knowing what to look for started to see clues of the problem. You can see small separations at the yellow arrows.
His description was “Cut 1 was my initial cut away from the identified bulge area. There are small detachments identified. If this was all that was found in the tire it would not be a serious issue.”
Then he sectioned again and he found the entire area let go.
His description was “Cut 2 location was identified by careful measurement of tread depth and I found a location with more wear than in other areas. The large detachments between the belts on both shoulders can be seen”
Here is his scale pushed down in each end measuring the detachment separation length.
His description was "Detach 2a &2b show the detachment on the opposite shoulder to be about 2" long”
His description was “Detach 1a & 1b show the length of the detachment to be over 11" long”
And this one really shows the detachment separation.
His description was “Detach Width shows the width of the two detachments relative to the tread width”
I asked him how did this happen? His response:
Why detachment?
There are a number of things that can cause this. They would primarily be a breakdown of the rubber that coats the steel. This could be due to a manufacturing error or simply the selection of a lower strength rubber which cannot tolerate the forces applied to the tire. Only lab testing can determine that. Sometimes detachments can be initiated by tread cuts or punctures but that does not seem to be the case of the tire I inspected. Detachments are one of the more difficult conditions to analyze as there is a need for a lot of additional background information and data.
From this investigation I have a perfect case to file a report with the NHTSA as I used the tires within the ratings. I have since filed 3 complaints, 1 for each tire. I’ll create a thread on how to do this filing. It is the only way we as RV’ers can help this cause of trailer tire failures become more known to the right people who can help. See here How To File a Tire Failure Complaint
There is now a growing understanding that for tandem trailer applications that a 20% more tire capacity reserve is needed to help hold up to the service of a multi axis trailer. In my case I am towing heavy, I am not overloaded, in relation to my tire capacity. When I upgraded I targeted to get as close as I could to the 20% reserve at the heaviest loaded tire. I had a choice of load Range E in the ST or go to 16" LT and deal with tire wheel well issues. I weighed the options and went LT. See here for more on the LT change ST225/75R15 to LT225/75R16 Conversion
While LT tires may not be for everyone, knowing your weights of each tire location and where you are in relation to the tire capacity reserve is something you can do. You can also not tow over 65 mph on ST tires, keep them at max side wall cold pressure at the start of each trip and use white tires covers over them when the camper is in storage.
Hope this helps someone in the future.
John
* This post was edited 12/09/12 11:14am by JBarca *
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Cheyenps
Yorba Linda, CA
Posted: 12/09/12 10:55am Link  |  Print  |  Notify Moderator
Spectacular post and analysis.
Thanks for sharing it!
Steve
2008 Thor California Summit 26RLS
2003 Ford F-350 SRW Crew Cab Utility
tanman32225
Jacksonville, Florida
Posted: 12/09/12 10:59am Link  |  Print  |  Notify Moderator
WOW what a great and informative write up. This gives me more information to look at and what to look for. I am quite sure others will appreciate all the time and effort you took to help understand how shoddy ST tires are and how china bombs become a bomb.
Great job.
ScottG
Bothell Wa.
Posted: 12/09/12 11:25am Link  |  Print  |  Notify Moderator
Great post. Thanks for taking the time to do this for us all.
Ramblin Recks
GA
Posted: 12/09/12 11:39am Link  |  Print  |  Notify Moderator
Thank you for the tire education! I just changed out all four 3-1/2 year STs because the thread was getting wider in the center of the tires. The surface area of the thread was not "flat" across from side wall to side wall.
Very interesting to see the "inards" of the tire.
Thanks again.
George and Ann
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB ,4x4,3:73, Retrax Pro, Q20
2014 Cedar Creek, 36CKTS, 640W Solar, MPPT60, Magnum 2000
Retired Army, but still working....until 2016
bfast54
Traverse City ,Mi.
Posted: 12/09/12 11:40am Link  |  Print  |  Notify Moderator
Fantastic John......!!!!!!!!! I had a tire failure, earlier this summer, which I cought JUST in time, with My T.P.M.S. , which I would now never tow without.....
The sidewall gave way, but....I would have been interested in seeing if this had caused the sidewall, near tread edge, to fail. But, alas....the tire is now ....long gone.
But...........thanks again...!!!!!!!!!!!!!!!!!!!!
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller">
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
Bob/Olallawa
Kitsap Co, WA/Bullhead City AZ
Posted: 12/09/12 11:58am Link  |  Print  |  Notify Moderator
Very nice job John, this tire thing is a real headache for me. I am running ST235/80R16-D tires now and am maxed out for room both inside the wheel wells (width and height) and distance between the front and rear tires. The tires are Goodyear Marathons which have not given me any trouble(luck, don't know). I am not maxed out weight wise on the tires,am under by about 2,200 pounds but I have not done the wheel by wheel weight yet. I will check this next Spring and see what the next move might be. I am leaning on staying with the ST and stepping up to the "E" weight range. All this reading makes my eyes hurt, by the time I finish a reading session I still don't understand all I read. I wish I could find a local tire guy I could work with and trust his information, it would be so much easier. As more and more LT tires are installed on RV I wonder if the failure rate will go up closer to the ST rates, or are they the answer to the tire problems we have. That is if there is room to upgrade to the size tires needed to carry the weight and safety margins.
Welcome to my home, that door you just broke down was there for your protection not mine.
oldtrojan66
central Indiana
Posted: 12/09/12 12:26pm Link  |  Print  |  Notify Moderator
Thanks so much for this detailed post. I have been (my wife says "overly") worried about this issue since getting our new-to-us fifth wheel with five year old tires on it. The fact that it sat most of its life means to me that rot is more of a potential problem than separation. But I never really understood the separation problem so many talked about. Thanks, again
2007 Jayco Designer 36RLTS
2006 F350 DRW 6.0 PSD (powerstrokehelp.com)
When you're born, everyone is smiling and you're crying. Live so that when you die everyone else is crying and you're smiling!
Tireman9
Akron, OH
Posted: 12/09/12 12:45pm Link  |  Print  |  Notify Moderator
Thanks again.
Please consider filing a complaint with NHTSA. Unless owners make the effort to report tire problems WITH THE NEEDED ACCURATE DATA there is little or no hope of improving the general quality of tires applied to RVs of all sizes.
* This post was edited 12/09/12 02:27pm by an administrator/moderator *
Tireman9
Akron, OH
Posted: 12/09/12 12:50pm Link  |  Print  |  Notify Moderator
Sorry for the headache. I can only suggest you take your time and work through posts and blogs based of facts and sound engineering experience. If you have questions go ahead and ask. There are a few tire engineers lurking around. [emoticon]
