RV.Net Open Roads Forum: What mistakes have you made that might help others...?
 > What mistakes have you made that might help others...?
Page of 19
d3500ram
Colorado
Posted: 02/17/13 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
There is another thread going about a member who shared with us his misfortune on his camper. In it, was a very informative discussion as to how best resolve the problem. But more subtle was the message for me to take some extra time when loading/ unloading my TC. I applaud that member for sharing. There were other members who were sharing their mistakes. And it got me thinking... can we post here what things you would like to take back (regarding TC's) that will help others by learning from mistakes.
I will read posts about putting gas in their diesel trucks on other forums. Every time I read problems like this it reminds me to take the extra time in order to not be "that guy." Whenever I read of others misfortune I vicariously learn through that person's mistakes.
I learned the hard way to make sure to pull the truck WAY OUT OF THE WAY once it is free from the camper. I once pulled out "just enough" and though it was enough space for the camper to be lowered. I recall kicking myself when upon lowering the camper did I realize the front portion of the overhead part (where it just starts to turn horizontal) had caught the rear part of the truck bed above the tail light. Jeez! only another 3" and it would have cleared just fine. Uhg! It dented the metal of the camper but did not puncture the skin. But now I make sure now that I pull the truck forward MORE than enough to insure room so it does not ever happen again.
Upon inspection pre-purchase of another past camper I noticed a clear outline of the end profile of a gutter. Yea, the kind on a house. When pointing it out to the owner they said yep, the TC was too close to the house when raising it (it was a pop-up TC.) I bought the camper and treated that dent as if I did it myself... The camper was in otherwise perfect condition except for this dent and it too was not punctured.
I have been lucky in my mistakes and no one was ever injured and these are very minor. What can you share (and perhaps laugh at) about your misfortunes that may help me and other to perhaps take away a learning lesson from your mishaps.
the tc life
colbert wa.
Posted: 02/17/13 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
make sure, and i mean DAMN SURE the black water valve is closed ALL the way. i did find out that from my valve to the caped end of the drain tube holds a "crap" load of fluids.
2010 adventurer 810ws
1999 c3500 dually 12' flatbed
THE TC LIFE
Jon L
Washington
Just backed into the shop door. I didn't have it up high enough. It looked wide open from the rear view mirror.
rickjo
SW New Mexico
Posted: 02/17/13 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
My Lance has struts (yes I know, the debate over the utility of struts is a ongoing discussion). I learned the hard way that only disconnecting one strut before unloading causes an awkward tilt to the camper when raising it on the jacks. Took me way too long to diagnose the problem, but ultimately no damage was done.
Rick
2019 F-350 4WD Crew Cab DRW 6.2 l gas engine (6500 lbs cargo capacity!)
2007 LanceMax 1181 loaded, King memory foam mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
JimBollman
Lost State of Franklin
Posted: 02/17/13 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
My rear hold down bar extends far enough that I have to remove the bar before driving out from under the camper. Forgot once and almost pulled the camper over on top of the truck when it hit the jacks. Got stopped soon enough but after getting the camper down on some blocks I had to take off the jacks and do some repair work to the jack bases.
kerry4951
East Central Pennsylvania
Posted: 02/17/13 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Tried to unload the TC one time and forgot to remove the passenger side Fast Guns. For some reason it would not go up like it should. Now I do a few extra walk arounds before I start pushing buttons.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
Ski Pro 3
bye
Posted: 02/17/13 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Took my fast guns off the truck mounts and left them to hang from the camper. That way they were on the correct corner of the camper for the next time I loaded up. Figured it would save time. After pulling the truck out from under, I lowered the camper. I heard the jack motors note change and stopped I saw my fast guns bowed pretty good from contacting the ground as the camper continued to lower. Lucky me, I was able to straighten them back out.
jefe 4x4
West Slope, Northern Sierra Nevada
Posted: 02/17/13 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Bought a Lance Lite camper assuming it had adequate insulation for the cooler months. NOT!
You would think it would be easy to originally install light weight insulation in a light camper for not much more cash.
Getting a camper with a heavy front window was a mistake.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
Grodyman
Enemy Territory
Posted: 02/18/13 12:16am Link  |  Quote  |  Print  |  Notify Moderator
I lowered a camper I previously owned into my truck bed, and forgot that I had stake bed tie downs that had raised metal loops on them...one of them went through the wood on the wing. Yep.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
run100
Arizona
Posted: 02/18/13 01:16am Link  |  Quote  |  Print  |  Notify Moderator
If you purchase a camper that comes with a brand new sewer hose, don't assume the clamp that holds the hose on the connector is fully tightened. If you make this mistake, the hose may pop off as soon as you pull the black tank valve.
Now, why would I mention such a thing??? Oh yes - the horror of horrors!
2012 F350,6.7L Diesel,4x4,CC,SB,SRW
2013 Lance 855S
Page of 19
