RV.Net Open Roads Forum: Travel Trailers: Awning LED Strip install
 > Awning LED Strip install
Page of 8
AaronV
Illinois
Posted: 04/14/13 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Most every project that I attempt outside of work(I am a carpenter) ends up having complications or just not going smoothly, even the simplest things. This project actually went real smooth and turned out surprisingly well so I feel the need to show pictures!
I've seen some threads where people go through the power awning power access area but mine was full of foam. I had to think of another approach so I bought a PVC junction box to hold everything water tight.
Used an old laptop power supply plug end to wire up to the 12v.
Everything tucked in the box with IR sensor out the bottom. I got the 12v from fishing wire up over the roof, down through the refer vent and spliced in behind the refer.
All closed up.
2013 KZ Sportsmen 242SBHSS
2005 GMC Sierra 2500 HD 6.0L
71stang99
Nevada
Posted: 04/14/13 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Looks great and another mod that I'll have to do!
Georshrwd
Bristow Va
Posted: 04/14/13 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
That looks sweet! Congrats on a nice job. How do you keep water from following the wire down the vent though? Any pics from that part of the install?
2013 Ram 1500 Laramie Longhorn
2013 Passport 23BH
AaronV
Illinois
Posted: 04/14/13 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
The vent hole is actually an inch or two above the roof line under the shroud, the water would have to run up the wire I would think.
beemerphile1
Ohio
Posted: 04/14/13 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Are the lights useable when the awning is closed? Looks like the light would only wash straight down the side and not shine out.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
AaronV
Illinois
Posted: 04/14/13 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I can answer your question next weekend. I just wanted the LED strip as high as possible so you the strip isn't as noticeable when not in use.
Georshrwd
Bristow Va
Posted: 04/14/13 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Got it! Again good job!! Looks great.
Beartoo
Perham MN
Posted: 04/15/13 04:50am Link  |  Quote  |  Print  |  Notify Moderator
t looks like a great Mod!
Will you please post a photo of the ligts at night after next weekends trip.
Thanks
Bear
DH - Bear
DW - Marge
Buster - English Springer Spaniel
Molly - English Springer Spaniel Puppy
07 Silverado 2500HD, Dmax, Allison Trany
Husky 15K
2008 Wildcat 24RL (Old Camper)
2009 Open Range 280 RLS (New)
Dandy
NorthEast
Posted: 04/15/13 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Really anxious to see night pics!!!
Great mod idea.
2009 GMC 2500HD Crew Z71 / 3.73 / 6.0L
2012 Prime Time Lacrosse 318 BHS Touring
Reese WD System with HP Dual Cam
Factory GMC Brake Controller
Factory Receiver Hitch
Factory Tow Mirrors
Jerallen
Pee Dee Region SC
Posted: 04/15/13 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Looks great!- pls post pictures in use with awning out.
What brand are the lights?
Did you use anything other than the adhesive pads on the strip to attach to the TT?
Page of 8
