RV.Net Open Roads Forum: Truck Campers: atwood jack repair
 > atwood jack repair
sleekcrafter
Northern Illinois
Posted: 05/02/13 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a repair thread for Atwood camper jacks? I have one that's problematic, and needs to come apart for lube or repair. For the price of replacements, I think it's worth a shot at repair. If there is a thread I would like to read up on it a little. Thanks!
2001 7.3L F350 CC SB DRW BTS auto, Elkhorn 11X TC, 31 Jayco Designer, 1979 Belco Tunnel Dragster DragBoat
KANSASBOB
Kansas
Posted: 05/02/13 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
I plan to disassemble one of mine (manual crank style) soon, but it may be a week or so. I looks to me like you drive the pin holding the gear on the top of the shaft, and the whole thing drops out the bottom. I would love to read a post where this has already been done too!.
I did read a thread on how to do it to Hapijac motorized units.... somewhere.
16 Elkridge E26
05 Dodge Ram 1500
KANSASBOB
Kansas
Posted: 05/02/13 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Found It!
Click Me
Kidoo
Chicoutimi, Québec, Canada
Posted: 05/02/13 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
KANSASBOB wrote:
Found It!
Click Me
I am working on my happijac with the use of this thread. Mine where rusted, bearings torn, o ring totally destroyed.
It was not a hard job, just remerber which way things go in and take picture. The worst for me was removing rust, it's very time consuming.
Good luck with your's
Monaco Cayman 34 2003, Cummins 300HP
Bigfoot 2008, 10.4, F350, 2006, Diesel 6.0, Black, 4x4, long box, Air lift, Rancho 9000, Rear sway bar.
54suds
adk mts.
Posted: 05/03/13 05:28am Link  |  Quote  |  Print  |  Notify Moderator
op asked about Atwood camper jacks
2017 Chev ltz double cab,drw,4x/torklift tdn's,30k super hitch 36" extention
1999 Bigfoot 1011
kohldad
Goose Creek, SC
Posted: 05/03/13 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Very simple to do and is as straight forward as it looks with one minor exception. The top pinch marks were a pain to ply out. Wish I had taken a picture when doing that one step.
This is the best I can remember, but have all the parts laid out on my bench. I can take a picture if needed. Had planned on doing it, but got involved in other projeccts.
Did notice that the main bearing is a custom Atwood piece. Quick look did not reveal any non-Atwood numbers and it did not seem like it would be easy to substitue. Since Atwood considers the jacks non-user repairable, not sure if they will sell the bearing to individuals.
The small parts you will end up with.
1) Crank jack to full extension. This will make seperating the inner and outer tube much easier later in dissassembly.
2) Remove cover
3) Remove roll pin from cross shaft that is located in cross shaft gear
4) Using a small nail, re-secure the gear to cross shaft. Rotate gears to make roll pin in lower gear accessible. It may be necessary to remove cross pin, reset upper gear and re-install.
5) Remove upper gear and cross shaft
6) Remove lower gear
7) remove lower roll pin, washer, split washer, and nylon bushing.
8) Seperate inner tube from outer tube.
This should be sufficient to service all components.
However, some may wish to remove the screw rod from the inner tube.
9) drive small chiesel between crimp and collar
10) holding the inner tube, use the screw rod and pull towards the chiesel and crimp. This should easily pry the crimp outwards.
11) remove small chiesel and replace with large chiesel repeat step 10.
12) repeat step 9 thru 11 on the crimp on opposite side.
13) once the crimps are removed as much as possible, use a hammer against the washer at the top of the screw rod to knock it out of the inner tube.
* This post was last edited 05/03/13 11:18am by kohldad *   View edit history
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 66,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
KANSASBOB
Kansas
Posted: 05/03/13 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Right.......... but some info on a similar jack seemed better than no info at all. Some of what went on with the Happijac should be useful when diving into an Atwood. [emoticon]
sleekcrafter
Northern Illinois
Posted: 05/03/13 09:09am Link  |  Quote  |  Print  |  Notify Moderator
This is the kind of info Im looking for, a few pictures would be great!
Kidoo
Posted: 05/03/13 10:24am Link  |  Quote  |  Print  |  Notify Moderator
For the thrust bearings, on the happijac, I went to an industrial bearing shop and they had the bearings in stock, maybe grainger would have something too. I doubt that Atwood would have a special bearing made for them but you never know!
kohldad
Goose Creek, SC
Posted: 05/03/13 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Add some pics and update the steps. If something isn't clear or you need another pics, let me know. This was a bent jack beyond repair that I took apart just to know how to do it.
Yes, a bearing distributor may be able to match it up. Shame that I forgot about using them, they have matched numerous bearings in the past when I was growing up on the farm.
