RV.Net Open Roads Forum: Travel Trailers: White lithium grease for the hitch?
 > White lithium grease for the hitch?
Robby9
Oklahoma City
Posted: 05/26/13 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
What do you think about using white lithium spray grease for the hitch ball and the spring bars? I've got the spray handy and don't want to open a whole tube of grease for this small job. Thanks.
powderman426
N. E. Ohio/The Villages, Fla
Posted: 05/26/13 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have pulled trailers for many years and never greased the ball, but if that's what makes you feel better why not put a piece of waxed paper over the ball before hitching. This way your wife wont have to wash the grease from your clothes.
* This post was edited 05/26/13 01:06pm by powderman426 *
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Lynnmor
Red Lion
Posted: 05/26/13 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
It should be fine. An EP (extreme pressure) grease would be be best, but any grease is better than nothing.
Turtle n Peeps
California
Posted: 05/26/13 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
I too have never put anything on my ball.
You could put it in the ball but I would not put it on the bars. That stuff gets like glue when it dries out. I learn the hard way when I used it on my tool box slides.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
GMT830
Maine
Posted: 05/26/13 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Apparently Reese sells an EP product with Teflon. Comes in a toothpaste tube. Over time is saturates the metal so less is required each use. I'm going to get some for the ball/coupler and spring bar pressure points.
I use Fluid Film for everything else.
Lena - 02 Yukon XL Denali
TT - Wilderness 29L
mlts22
Austin, Texas
Posted: 05/26/13 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I've read a number of items to address ball gall. Some use waxed paper, others use a lithium grease. Still others just don't bother.
Pretty much any lubricant that is tenacious should do the job.
Huntindog
Phoenix AZ
Posted: 05/26/13 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
What I have noticed is that as my TTs have gotten heavier over the years, is that grease becomes more necessary. A 14K ball isn't all that cheap, so I grease it. I use wheel bearing grease and a disposable rubber glove. Works well.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
brirene
midwest
Posted: 05/26/13 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
I used white lithium for thousands of miles when I had my tt's. Worked fine for me.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
JimBollman
Lost State of Franklin
Posted: 05/26/13 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I use a little silicon grease once a year and it seems to last all year. I just happen to have a tube is why I started using it instead of something else. I also pull my receiver when ever I a hook the trailer and then put a plastic bag over the end and drop it in a denim bag for storage behind the seat.
Robby9
Oklahoma City
Posted: 05/26/13 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
The Reese grease in a tube sounds convenient to keep in the TT tool box. I'll look for some.
If I don't keep the weight bars lubed they squeak and groan and are generally annoying.
