RV.Net Open Roads Forum: Class A Motorhomes: Magik's Class A
 > Magik's Class A
Page of 10
magik235
Central Wisconsin
Posted: 06/02/13 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I got my Class C out of storage 2 weeks ago then bought a 25' Class A. It is a 1993 Damon Challenger and has a fuel injected 454 Chevy engine with overdrive transmission. We went to Willow River State Park in Hudson, WI with friends for our maiden voyage. Everything went well. We put on 350 miles for the test run. It tachs 2100 at 69 mph. Here is a picture of it next to the other one. It is only 2 feet longer.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26989746.cfm
hershey
Albuquerque,(fulltime) NM, USA
Posted: 06/02/13 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Both are really nice looking RVs.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
JanTx
Above
Posted: 06/02/13 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
which one to YOU like the best?
Janet N Texas
glamisorbust
Arizona
Posted: 06/02/13 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Sharp looking, classic rigs!
1999 Holiday Rambler Endeavor 38'. Cummins ISB 275, allison 3060.
Toys pulled: 22x8.5 open deck PJ flatbed. 5200# axles. Sand car with ecotec engine. Multiple 1980's ATC's(3 wheelers). We're duners!
magik235
Central Wisconsin
Posted: 06/02/13 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
There is no comparison between the two. The Class A is far superior. Speed, power, RPMs, interior and driveability are all much better.
Jim@HiTek
Gresham, OR, USA
Posted: 06/02/13 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't mention the fuel mileage you got at 69MPH.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
magik235
Central Wisconsin
Posted: 06/02/13 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't calculated it yet but I expect it to be better than the 8.3 mpg I get with the Class C.
magik235
Central Wisconsin
Posted: 06/09/13 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
It has been raining constantly in Wisconsin so out side work has been difficult. I replaced broken exhaust hangers. I washed the passenger's side then used Scrubbing Bubbles to clean it again. Next I applied Meguiar's Ultimate Compound to remove oxidation and clean the fiberglass. Finally I applied 2 coats of Nu Finish. I got the top half of the driver's side done using the same process.
I thoroughly cleaned the inside and installed a new stereo system. I relaced the rubber seals on the fresh water tank's connections and fixed the level indicator lights.
magik235
Central Wisconsin
Posted: 06/22/13 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
We put on 250 miles going to Stand Rock campgrounds in Wisconsin Dells, WI.
magik235
Central Wisconsin
Posted: 06/23/13 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I finsihed the bottom half of the driver's side using the same process as outlined above. I used Scrubbing Bubbles to remove the bugs from the front. My fresh water drain does not seal completely and water dripped out of the tube so I capped it off for this year. I swapped the Optima batteries from my class C into the Damon.
Page of 10
 > Magik's Class A
