RV.Net Open Roads Forum: Truck Campers: Yet another wobbly legs story
 > Yet another wobbly legs story
Terrick down Under
Australia
Posted: 06/04/13 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Firstly, I must thank KKELLER14K for the incentive to get off my butt, and do something about the unsteady legs. His leg brace gave me the starting point from which this was all developed. As mentioned in an earlier blog, we had some damage to the front LH corner leg that got me searching for answers and ideas.
Secondly, if you have more damage then you should look at AnEv942’s report on his mod/repair labelled “slide repair” which is very detailed.
Step one; get some paper, pencil and tape measure. I also made a cardboard template o the legs to dually fenders fully loaded, so I could make measurements at any time.
Measure the width between the leg mounts, mine was 94 ½”, for the 3”x1” tube steel, (minus the thickness of the end plates). The end plates are 5”x2”x ¼” mild steel and the holes were drilled to match the leg mounting points. The 4 bolts had to be removed and replaced with longer ones.
Then I picked up some ½” pipe (about 7/8” outside diameter), mine were cut approximately 19” for the 2 front braces and 22” for the 2 side braces. One end of each is squashed flat for about 1 ½” so you have a good area to drill thru nice and flat, remember to put the pipe seam where you will be drilling, because if it is where the pipe folds over 180 degrees then it will split there. The other end is cut at approximately 45 degree AT A LATER STAGE, to suit your frame. The 2 pieces that get welded to the angles are 1”x 2”x ¼” flat steel, rounded at each end to make them look nice.
Next, 2 pieces of 2 ½” x 7” x ¼” was bent to suit my legs, so that the braces will fold up when traveling. A good vice and big hammer and slowly pound away as close to the bend line as possible. When mounting to the leg MAKE SURE that the bolt is not too long or you will damage the leg tube!
The pivot bolts were high tensile 3/8” x 1” with nylock nuts. The end brace pins are simply s/s dyna bolts without the outer sheath. For the vertical ones I simply machined off the excess thread so that what was left smooth to make getting the pin thru the hole easier. Install the braces to the folded bracket that is bolted to the leg, then swing the front braces up to the cross brace and use a bit of “Bluetac, wall poster sticky stuff” to hold in place. CHECK that the camper and legs are level and plumb NOW. Also make sure you can remove the front cross brace s/s pin when loaded. Now you can drill up thru the angled brace to the cross brace for the retaining bolt hole.
Make sure that the front braces clear your fenders when unload/loading, I gave myself about 2” total, because we often unload/load on uneven ground.
I painted everything after a dry assemble was done, to make sure that everything worked and folded up properly. If you are painting during cold weather, then warm up the steel first to make sure the paint sticks, I had it all hung from coat hangers and old bolts stuck into the vice for holding things so that I could paint all over at once. I walked like that fellow form Notre Dame by the time I had finished.
Now when the legs are up and swung in, I swing them all the way so I have more mirror view when driving, also more clearance for the back passenger doors on the cabin, then I put a small bungy strap from the hardware store to make sure they did not rattle and to keep the leg from rattling down while driving, someone else already mentioned this…I thought better safe than sorry.
Another idea that 2 other RVnet’ers came up with was to run a length of Unistrut from the front to the back to support the underside and give better tie-downs a better anchor point. This was then bolted to the front cross bar to join them together. I used to remove the tie-downs when unloading, but now leave them hanging so that I can see them. The tie-downs connect to a ½” high tensile bolt going across the Unistrut.
Hint: If you can’t weld or bend yourself, then mark everything with permanent marker so the tradesman can line things up exactly for you. You could also print the pics of and show them what you are trying to do.
I hope that helps, Again thanks to all those who inspired me to get of my butt.
Maximum photo width=640
* This post was last edited 06/04/13 10:40pm by an administrator/moderator *   View edit history
Photomike
Southern Alberta or where the camper is parked!
Posted: 06/04/13 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Nice Mods!! I am sure that the TC manufacturers have tested jacks time and again for safety the way they are sold, and I am sure that they are safe. That being said I would rather be a lot more sure that my investment is going to stay supported with a little extra support!
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
Terrick down Under
Australia
Posted: 06/04/13 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Photomike, I'm not questioning the Manufactures, but the idiots like me that have put undue stress on the mounting components, thru being in a hurry or just not knowing enough, don't help things to stay upright.
One of the other RV.net'ers said he allows himself 2 hour to get ready. Our first load took 3 1/2 hours, the next we had a friend helping, it took the same time. Now, I put DW behind the wheel and we have hook up done in about 5 minutes, I just tell her left or right hand down on the steering wheel and slowly back on the brakes, then another 20 to load provisions and we are off. No other help wanted.
Mind you , I have also painted white lines down the centre of the bed, marked centre of the camper both front and underneath, and use the legs as a guide also.
If there is anything else to make it easier and safer then I will do it.
jimh425
Western MT
Posted: 06/04/13 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Cool job.
69 Avion
Phoenix, Arizona
Posted: 06/05/13 12:06am Link  |  Quote  |  Print  |  Notify Moderator
Very nice braces. They sure are a lot stronger than when they came from the factory.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
cewillis
Tucson, az, usa
Posted: 06/05/13 09:23am Link  |  Quote  |  Print  |  Notify Moderator
That's great work. Maybe more solid now than your house. (not really)
Cal
