pa traveler
usa
I had rv dealer try both side by side and the sensar 4 with batwing worked much better, had him install it,got rid of the jenson junk.
MNtundraRet
Bloomington, MN
Hi everyone:
I just revived Jeff's old post since many have been reading the recent posts on using different RV antennas and added amplifiers. ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I hope it helps some of you.
Mark B.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
RoyB
King George, VA
I did my comparison test here in King George VA with my antenna mount about 12-feet in the air attached to the side of my OFF-ROAD POPUP antenna.
King George is almost located right in the cent of Richmond Va and Washington DC HDTV Towers being 50-60 miles apart...
The Richmond Towers are for the most part all in the same location where as the Washington DC towers are spread apart many miles on the East and west side of the town.
I used the BATWING with the added dipoles and the JACK antenna both powered by the same 12VDC going up the RG cable from the Antenna Panel inside my POPUP trailer...
This was all done with just being able to pick the HDTV channels with no logging in of signal strength readings...
Both antenna picked up all of the transmitting HDTV Digital frequencies. i.e. I scanned in all of the same digital transmiter frequencies on my VIZIO HDTV set.
The problems I encountered was I had to move the KING antenna more precisely to zero in on the transmitted HDTV signals than I did with the BATWING antenna.... Once tuned in they looked the same quality on my VIZIO HDTV set.
I did not have to move the BATWING antenna around to pick up all of the transmitter station. I did have to find the good center position to do this however. I had problems with my CBS station which is the one Ilike to watch the most here. I could zero in on the CBS tower but would lose some of the others. I finally found the happy medium spot where all them worked with one position setting. I also noted that when using the JACK antenna overhead aircraft would sometimes give me pixel break-up in the received signal reception. Never seen any of that with the BATWING antenna.
All of this simple testing made the BATWING the winner for me haha
I now use the JACK antenna here on my house pointing towards Charlotsville and the BATWING Antenna on my off-road popup trailer...
![[image]](http://i.imgur.com/eqaVpto.jpg)
Roy;s image
Actually the best reception I got was using a different 8-bowtie antenna panel but I am sure it would not survive all of the putting up and taking down so it lives on the peak of my house here in King George. This $60 dollar antenna has two banks where you can point to different directions and it really works great pointing towards Washington DC to pick the wide spread of HDTV towers on both side of the local town. I am picking up a good 80 plus OTA TV signal free to the public doing this... All in high def TV reception...
![[image]](http://i.ebayimg.com/00/s/MzczWDUwMA==/z/96YAAOxyYYlRwQga/$T2eC16J,!zoE9s5nd0o2BRwQg,Cnrg~~60_35.JPG?set_id=880000500F)
Google Image
My plan B for when the local cable company goes down...
Roy Ken
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
SCVJeff
Santa Clarita, CA.
Move 20 miles farther out and repeat
Jeff - WA6EQU
MrWizard
Traveling
I think...Unless he went West, aka sideways
His 60/50 would become either 80/30 or 40/70
He did say his campsite was between D.C. and Richmond Va.
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
BcBorn
British Columbia
King Jack has improved/redesigned their King Jack in the last couple years.
Time for a new shoot out.
Dutch_12078
Winters south, summers north
BcBorn wrote: King Jack has improved/redesigned their King Jack in the last couple years.
Unless they've done a radical redesign that isn't obvious in the photos, it still sucks at low-VHF reception.
Dutch
2001 GBM Landau 34' Class A
LouLawrence
Traveling the US!
Since the basic size and shape remains the same, the interior elements are still limited in size and capability.
It's highly unlikely that the results would vary by enough to be notable.
Blaze1024
Sacatomatos
Very interesting, I did similar testing a few years ago, the only difference was I was using Agilent equipment versus R@S
and my results were significantly different than yours ?
On UHF both antennas performed nearly identically which is to be expected because if I remember correctly both are simple 3 element designs.
whether it's a yagi or log periodic design it doesn't matter as a 3 or 4 element yagi is gonna perform pretty much identically to any other 3 or 4 element yagi and likewise a 3 or 4 four element log periodic is going to perform nearly identically to any other 3 or 4 element log periodic.
so if you're seeing a couple dbm difference between two four element antennas then you need to question your setup because something is not right. In engineering we call these sanity checks.
I mean something as simple is forgetting to move one antenna out of the near field of the DUT will cause problems. I mean you do understand that leaving say the winegard antenna anywhere within a dozen or so wavelengths of the king while the king was being tested would impact the performance of that antenna.
The bottom line is that there are so many variables when doing antenna system tests that without a video or detailed explanation of the setup it's hard to take the results seriously.
There is a reason why antenna tests are performed inside an Anechoic Chamber or for larger antennas at a remote antenna test range
By the way, I'm a retired engineer, my primary area of expertise is in RF electronics primarily microwave. I was also former VP in charge of prototype development for a well known aerospace company, many of the projects I worked on are flying in space right now.
The bottom line is your results don't seem to pass the sanity check, you're seeing significant differences in received signal strength between two nearly identical antennas at least on UHF, In Fact if I remember correctly the UHF add-on to the batwing is purely parasitic to it's active VHF side.
the king antenna is primarily a UHF antenna, so it's performance on VHF is not gonna be nearly as good as the winegard which has a dedicated VHF dipole. If anything the VHF dipole acting as a parasitic element on the UHF side is going to cause problems. Keep in mind dual band antennas are never as efficient as single band antennas, primarily because you can never eliminate all the interaction.
Anyhow if I recall correctly when I performed a similar series of tests the results were nearly identical on UHF between both antennas with the king being ever so slightly more sensitive on UHF, so you might wanna go back and review your setup, it's even possible that one of the antennas may have been defective
oh but hey good job with all the snapshots.
SCVJeff wrote: I finally had time to buy a King Controls Jack antenna (on sale) for a shoot-out with my existing Winegard Batwing antenna with the Wingman add-on.
edited 02/01/23 08:48pm by Blaze1024 *
Tom_M
New Hope, MN
This thread is almost 10 years old. I do not have access to a spectrum analyzer but my tests were vastly different from SCVJeff's. For me the Jack was on par with the Batwing for the UHF band but did poorly on VHF.
SCVJeff has not been active on this forum for several years.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
