RV.Net Open Roads Forum: Truck Campers: Under Bumper Storage shelf
 > Under Bumper Storage shelf
CAJW
NorCal
Posted: 09/01/13 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Not liking the fact that my leveling blocks took up valuable storage space (under the dinette) and not wanting to put them inside the camper or truck, I came up with this variation for storage. I'd seen other ideas to mount the blocks on the bumper which is easy to access, but I wanted to keep that area clear as I hang my BBQ in that area and also needed a place to carry my expandable sewer hose support. The shelf I designed is made from 1" angle iron with an expanded metal floor. 1/8" steel straps hold it from the bumper support and the bumper/septic hose storage on my Arctic Fox 996. It stays attached to the camper,doesn't decrease ground clearance nor does it get in the way while loading/unloading the rig. I've yet to take it on a road trip, but so far so good and it keeps those dirty leveling blocks outside where they belong!
View from the rear.
Driver side view.
Driver side view front angle.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
Butch50
Bentonville, AR
Posted: 09/01/13 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Really lloks good but a question are you going to add something to keep the blocks or the slinky support from bouncing out as you drive down the road. Might have to look at something like that myself.
Butch
I try to always leave doubt to my ignorance rather than prove it
2017 Ram 3500 Mega DRW
2018 Grand Design 303RLS
CAJW
NorCal
Posted: 09/01/13 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, have 11" x 1/4-20 bolts secured with wing nuts and drilled to accept a hairpin type clip to keep the wing nut from coming loose. Planning on running a small cable through the hairpin clips to keep track of them. A little JB weld on a fender washer keeps it attached to the bolt head so less to juggle and keep track of when taking the blocks out.
Scott16
Planing to buy. Research in progress
Posted: 09/01/13 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Really good job.
Thanks for sharing the pictures.
Scott
US Navy Retired IC1(SW)USS Fletcher DD-992
Photog101
Sparta, TN
Posted: 09/02/13 03:22am Link  |  Quote  |  Print  |  Notify Moderator
That's a great idea. I have been toying with putting a rack off of the receiver and under that empty area on my rig.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
mark_be
Belgium
Posted: 09/02/13 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Good idea, but aren't you going to loose stuff on the road this way? Or is it still incomplete at this moment?
2001 Ford F350 7.3 Diesel (DRW Crew cab Long bed)
Sonnax TQ and Sonnax 4R100 rebuild - 6.0 transmission cooler and OTW cooler.
2011 Arctic Fox 992 - 2.5kW propane generator - 315AH Trojan batteries - 2kW pure sine wave inverter - 140Wp solar
CAJW
NorCal
Posted: 09/02/13 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Guess I should've put the hold down bolts in for the picture. I noted the details in the third post from the top, but will post up one when I finish the cable idea I noted.
CAJW
NorCal
Posted: 09/02/13 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I've looked at that wasted space area since we got our AF and toyed with enclosed tool type boxes, tubes, etc.... Access was the main problem, with the side being the logical point to get items in/out and couldn't find a box that had an end door with the right dimensions.
Thank you for your service to our country. I had a low lottery number, but thought I might end up going anyway.
trail-explorer
NM
Posted: 09/02/13 09:42am Link  |  Quote  |  Print  |  Notify Moderator
NICE WORK!!
Nice thing about the Fox Landing bumper is that the mounting brackets extend far enough forward to allow adding things on to it.
Bob
jimh425
Western MT
Posted: 09/02/13 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Looks like nice work on the install, but that's pretty low for anything other than road use in great weather. How are you going to keep them reasonably clean?
