RV.Net Open Roads Forum: Pics: Slide mechansim, Winnie/ Power gear / Kwickee
 > Pics: Slide mechansim, Winnie/ Power gear / Kwickee
Lt46
Central Florida
Posted: 08/28/16 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Jeepinjohn,
The post you responded to was made in 2013. You'll be lucky if the OP responds. You might try to private message him for answers.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
spotrot
Indian Rocks Beach, FL
Posted: 08/28/16 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
If memory serves, if you can get to the pin that holds the worm gear shaft to the gearbox shaft, and to the two pins that connect the nut to the slide, the job is fairly easy.
The shaft and broken nut can then be pulled out after the plate on the end of the tube is removed. I had to support the slide to do that.
Email me if you'd like the couple photos and pdf files that may be of help.
car54Don
west coast north of the 49th
Posted: 07/23/19 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
greetings. I am going thru same slideout repair, kwikee FLS slideout rail. On the galley the rear arm is failing as a result of the plastic 1" acme nut. You mentioned that you bought the part for about $6. Where at? Need parts asap.
thx in advance
Don
bjbear
Cold Lake, AB, Can
Posted: 07/24/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
thx in advance
Don
Try https://www.amazon.com/Power-Gear-1612554-Inch-Plastic/dp/B00RJBTX7Y
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
jspringator
Versailles, KY 40383
Posted: 08/09/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a to update this slide to make it more reliable? I am very reluctant to use the slide because I'm afraid I won't be able to retract it.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
sean farrell
Livermore, CA
Posted: 09/21/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
The problem was the slide out would no longer retract(one side)The broken part is called a "acme nut". The part was no where to be found so I had to make one , If your having the same problem and have the same type of slide maybe this info might help you. I have a 2002 Minnee 31",slide type Kwikkee Dyno Sycn worm drive. Here's how you know it's the acme nut, first room starts going out crooked, and retracting room is getting worse,finaly quit retracting (one side) at all.Second clue is you get out the hand cranks and manualy cranking is not moving room in. The factory uses a plastic acme nut threaded onto a long worm screw to move room in and out,the platic nut breaks loose and spins in its location and your room is broken. I was not able to find parts for this problem, I called and looked everywhere , no parts! So I replaced the plastic nut with a bronze acme nut from Nook Ind. and a steel sleeve, yes it took some time and frabrication but my slide out is back up and working great,If you need info on parts/install,be glad to pass along.
jspringator
Posted: 11/01/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I just ordered 2 ACME nuts and 4 pins from Lichtsinn RV. Never can tell when I might need them. I was afraid they were going to be unavailable.
