RV.Net Open Roads Forum: How to fix Dometic Comfort Control thermostat problems
 > How to fix Dometic Comfort Control thermostat problems
dougrainer
Carrolton, Texas
Posted: 08/19/17 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Megmcc08 wrote:
The a/c wont come on. It's a domestic dual thermostat. The 10 button. We tried switching with new thermostat. We flipped breakers in/outside. I looked at the circuit boards and don't see any burned wires. We just had the whole unit replaced in both a/c. I am not sure if it's a voltage problem. I get nothing on thermostat so it's incredibly hard for me to diagnose issue. Any help greatly appreciated. 5th wheel crusader 2014.
You need to start a NEW Thread, not hijack a old thread. This will get you the info you need faster. WHO replaced the unit/s. Your post does not make sense. ----"We just had the whole unit replaced in both a/c". BOTH roof top units replaced? Once we determine who replaced them will determine what to look for. Doug
Cwest17
Colorado
Posted: 09/17/17 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2016 Grand Design Imagine. When I turn the furnace on, the air conditioner comes on also so both hot and cold air is blowing. Any suggestions?
dougrainer
Carrolton, Texas
Posted: 09/17/17 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I doubt cold air is blowing. In the Tstat settings on a Dometic 12 button or Zone Control tstat. You MUST select AUTO for Fan speed selection to prevent the AC blower from coming ON. If the Fan is set to Lo-Med-Hi the AC blower will run when Furnace is ON. Doug
jjcook
Maryland
Posted: 04/06/18 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
We have 2017 cedar creek silverback with 2 a/c units controlled by a Dometic comfort control center 2 thermostat I cannot get it to display anything about zone 2 I have reset it the way the manual says but still nothing. Any help will be greatly appreciated .
2013 GMC 2500 crew cab Denali , 6.0 , 4:10
2003 Cardinal 29WBLE
16K dual pivot Husky Slider
dicksop
Edmonton, Alberta
Posted: 09/04/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I was reading the posts of how to fix Dometic issues and wanted to chime in with my issue and if anyone had seen it or knew how to fix it.
I have a 4 button dometic with two AC units.
When it worked, the digital display showed all the info including the zone 1 or zone 2 that I was configuring and looking at.
All of a sudden when I turned on the comfort control the zones did not show up on the display, nor did either of the AC units work.
After fumbling through a few wires on the AC 1 unit, I disconnected one of the phone connector cables and the front AC unit began to work. The rear still would not work. Also after having the front AC run for a while, I noticed it was not turning off when the temp on the display (by the way the zones 1 and 2 still was not displayed) was reached. It just runs continuously.
Any thoughts or ideas? I really do not want ot go buy the 10 button unit with control boards if I dont have to..
Peter
dougrainer
Carrolton, Texas
Posted: 09/05/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Peter
Y
Your 4 button is over 20 years old and they dropped the 4 button due to the same issues you are having. You can either buy the 2-- 10 control boards and the 10 button or you can buy 2 -- 5 Button control boards and the 5 button. You also need to replace the 4 wire phone end plugs as a maintenance issue. Doug
