RV.Net Open Roads Forum: Tech Issues: My favorite Generator
 > My favorite Generator
pnichols
The Other California
Posted: 11/27/13 12:45am Link  |  Quote  |  Print  |  Notify Moderator
NinerBikes wrote:
51 pounds is 3 pounds more than a Honda Eu2000i. For 1/3 the wattage.
The EX650 may be "more reliable" too - many running EX650s are going on 25 years old. How many EU2000is are that old yet? Maybe an EU2000i will go that long and maybe it won't .... unknown as of right now.
A running EX650 can be bought for $200-$350 ... a bit less than any runnning used EU2000i can be bought for.
Also, an EX650 putting out it's maximum constant power of 550 watts is still only 54 dB in loudness. I wonder how loud an EU2000i is when it's rev'd up so as to be above it's idle RPM enough to output 550 watts?
Remember that to use an EU2000i's power range you have to put up with a loudness range of 53 dB up to 59 dB. Regarding the EU2000i when outputting it's maximum power (which, granted, is way higher than an EX650's maximum power): I've heard EU2000i generators running at full speed and it isn't pleasant ... not only are they at 59 dB, but it isn't the mild humming sound that the EX650 puts out no matter how much of the EX650's total power is being called for.
I'm not saying that the EX650 can "replace" an EU1000i or EU2000i for all RV uses. I'm saying that the EX650 is almost the quietest non-solar way to dump up to 30 amps into RV batteries during recharging. (For what it's worth, the quietest non-solar way to charge RV batteries anytime anywhere is with an automatic fuel cell system in the RV.)
Phil, 2005 E450 Itasca Spirit 24V
DryCamper11
Hartford
Posted: 11/27/13 07:31am Link  |  Quote  |  Print  |  Notify Moderator
My favorite generator is the CCK 4KW Onan installed in my RV in 1973. It has only been out of the RV once in its entire life (for an upgrade), and it still runs as well as the day it was installed. It's solid cast iron and near indestructable. I know it's not fancy, not light, not state of the art and not as quiet as inverter gens, but it's there when I need it, and with just a bit of TLC, it will still be running when I decide I can't go RVing any more. I just have a soft place in my heart for that old heavy beast of a chunk of iron.
In the Boonies!
KJINTF
Western Montana
Posted: 11/27/13 07:51am Link  |  Quote  |  Print  |  Notify Moderator
DryCamper11
I had one of those old Onan's for years and loved it's twin cylinder pressurized oil system with screw on filter. Got a new Rig and a POC Onan 4Kw Spec"K" single cylinder with a splash oil system - I hate it and wish I had kept the older one
Gave away my old Honda EX650 no need for it anymore which we purchased new in early 90's it still ran great.
My favorite gen is my Honda EX5500 Electric start, Liquid cooled, Acoustic damped, Two cylinder, Pressurized oil system with spin on filter been going strong for almost 20years
Retired & Loving Life
DryCamper11
Hartford
Posted: 11/27/13 08:39am Link  |  Quote  |  Print  |  Notify Moderator
KJINTF:
My CCK is prior to the era of that fancy improvement Onan made: oil filters! It's got none - just splash lubrication. I do have an Onan NHD 6500 with that new-fangled oil filtering system.
The CCK doesn't even have electronic ignition - it still uses points! I need something to use my old automotive timing light and test tools on. [emoticon]
I'll admit I do like Honda small engines, however. My 1983 Honda lawnmower is still running great.
mlts22
Austin, Texas
Posted: 11/27/13 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Pressurized oil systems always win in my book compared to splash lubricated systems. The oil has to "do" less work. With splash lubricant, that little amount of oil that is thrown out of the pan has to perform a lot of work, while the rest of the oil in the pan does nothing. A system pushing oil around means that more oil is seeing duty to carry heat off and limiting wear.
Onan or another company would make a killing in the RV genset market by making an inverter generator that is coupled with a decent sized battery, and having the generator run on something similar to eco-throttle. If a large load hits, the battery would carry it (like the Yamaha 3000iSEB's mechanism) for a short time until the generator is up to speed. The result would be a nice, quiet, economical genset.
pnichols
Posted: 11/30/13 12:13am Link  |  Quote  |  Print  |  Notify Moderator
.... or how about one of these built-in automatic start/stop generator setups that are only 54 dB loud (quieter inside an RV's cabinet) and skip the 120V AC step completely. Just run your entire RV off 12V DC from your battery bank and 120V AC from an inverter off your battery bank (including the air conditioner) while this great piece of engineering takes care of the batteries quietly anywhere, anytime, any weather:
http://fischerpanda.com/marine-pdf/AGT4000-DC.pdf
Limelight
Home
Posted: 08/09/19 01:50am Link  |  Quote  |  Print  |  Notify Moderator
mtnman1989 wrote:
I have four generators, a 5000 watt Generac home backup system, a 4000 watt Onan on my motorhome and a Kawasaki 1400 watt I use with my travel trailer. I also have an old 1985 or 86 model 600 watt Nissan, my favorite. This little tiny 600 watt generator is an awesome little generator. I learned that it is actually a Honda generator made for Nissan. I use it with my motorhome when we are boondocking and just need to charge the batteries or play the TV etc. It only holds about a pint of fuel and will run about 5 hours before it needs refueling. It is very quiet, light weight, sips fuel and easy to start.
mtnman
I have recently acquired a Nissan GL600 generator, what type of oil does it take?
Limelight
Home
Posted: 08/09/19 01:51am Link  |  Quote  |  Print  |  Notify Moderator
What type of oil does a Nissan gl600 use?
bikendan
Camano Island, Wash.
Posted: 08/09/19 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Limelight wrote:
mtnman
Holy Thread Resurrection, Batman![emoticon]
A 6 year old thread brought back to life.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/10/19 03:07am Link  |  Quote  |  Print  |  Notify Moderator
And I had to settle for a Harbor Freight TOO-cycle to get the same performance and weight.
Sigh
