RV.Net Open Roads Forum: Class A Motorhomes: 6v vs. 12v house batteries
 > 6v vs. 12v house batteries
carp65
Sioux Falls, SD
Posted: 12/02/13 08:30am Link  |  Quote  |  Print  |  Notify Moderator
If you have 4 6v house batteries, would you be better off to replace
them with 2 12V house batteries.
enblethen
Moses Lake, WA
Posted: 12/02/13 08:47am Link  |  Quote  |  Print  |  Notify Moderator
My opinion is no way would I change back to 123 volters for house batteries.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
donn0128
Pronounced Ore-gun
Posted: 12/02/13 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Only if you NEVER rely on battery power when boon docking. I have 4 golf cart batteries and can along with my solar panels boon dock for 4-5 days even on cloudy days before I need to use my generator. Previously I had 4 12 bolt batteries and had to use the generator every couple of days under similar circumstances.
RoyB
King George, VA
Typically four each 6V batteries (Two groups of two 6VDC batteries in series) will give you around 450AHs of battery capacity.
Two standard 105AH 12VDC batteries in parallel will give you 210AHs of battery capacity.
Depends on what you need to have your battery capacity supporting when you are camping off the power grid..
Roy Ken
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
2oldman
So Cal
Posted: 12/02/13 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Better off in what way?
2- 12v or 6v June 2013
12v vs 6v batteries 2013
12v vs 6v batteries 2006
More 12v vs 6 2006
12v vs 6v 2010
Why 2 6? 2006
zmotorsports
Utah
Posted: 12/02/13 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I would stick with the four 6-volt batteries wired in series/parallel. This will generally give you more than double the amp-hour capacity. If you never boondock and cost of two vs. four batteries is driving this decision then you could get by with the two 12-volt batteries pretty easily.
Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
Posted: 12/02/13 09:36am Link  |  Quote  |  Print  |  Notify Moderator
This is a common question here. Are six volt pairs or 12 volt singles better.
(NOTE: you have 2 pair or 2 singles in your question)
The answer is a bit more complex than YES/NO but the answer boils down usually to Six Volt pairs are best.
The reason: COST.
now... Here is why.
When you talk about 12 volt there are many different batteries,, Group 24,27,29,31, 4-D 8-D and dozens of others not listed.
Each battery is a diffeent size.. Group 24 for example is about 75 amp hours.
8-D around 250. (They are heavy and expensive).
The better question is this: What TYPE of battery.
Starting batteries like to be well fed, If you run them down to half full they get kind of unhappy and may well not recover.
Marine/Deep Cycle are starting batteries first, with lip service to deep cycle, Though they can recover from a lower discharge than an engine type battery, they still object to 50 percent
DEEP CYCLE batteries, such as Golf Car batteries, do not object to 50% discharge, provided they are recharged swiftly.
And when it comes to DEEP CYCLE the common GC-2 Golf car battery is the most popular, it's made in great quanities and thus costs less per unit than other large lead acid batteries.
HOWEVER: There are a couple of golf car companies using 12 volt batteries now,, This is going to result (over time) in 12 volt DEEP CYCLE batteries dropping in price.
Testing says I need to replace my GC-2's soon. At 8.5 years they finally bit the electrons.
harold1946
surprise Az.
Posted: 12/02/13 09:43am Link  |  Quote  |  Print  |  Notify Moderator
You must have had rather small 12 volt batteries. I have three that are 245 AH each, total 735 AH.
8D AGM deep cycle.
* This post was edited 12/02/13 10:05am by harold1946 *
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
VintageRacer
Tatamagouche Nova Scotia
Posted: 12/02/13 09:52am Link  |  Quote  |  Print  |  Notify Moderator
For me the answer comes down to weight. A given battery is going to weigh a certain amount per amp/hour per cell. A deep cycle battery with a decent amp-hour per cell rating is going to weigh around 75 lbs for a 6 volt battery and 150 lbs for a 12 volt battery. I have both, and I much prefer installing the 6 volt batteries...
I have 6v deep cycle US2200 at 232 AH, and some 8D 12V start batteries (not deep cycle) at 245 AH. I need to stretch and do deep breathing before I install the 8D's...
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
pianotuna
Regina, SK, Canada
Posted: 12/02/13 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If you boondock and wish to run an inverter at high loads then 12 volt jars may be best. If you have room, weight capacity, and deep pockets then what harold1946 is lovely.
If you don't boondock then a single 12 volt deep cycle type battery is all you need.
Regards, Don
